exhaust leak, need a little help
Old Feb 25, 2007 | 12:15 PM
blitzblue1032's Avatar
Scion Noics
Default exhaust leak, need a little help
ok so i just need a little help here lol. i have a small exhaust leak on my turbo tc and i was told that i could just have it welded or something else to stop it from leaking. anyone have any suggestions? if this particular area (in the red box) can be welded then i would rather do that since it would be a much better permanent fix and i can have it done by tomorrow lol. if not though, does anyone have any other suggestions on how to fix it? its not really causing a prob that i know of, would just be piece of mind to have it fixed, thx! http://www.putfile.com/pic.php?img=4853784 http://www.putfile.com/pic.php?img=4853787 http://www.putfile.com/pic.php?img=4853786
Old Feb 25, 2007 | 12:19 PM
BBScion05's Avatar
Where is your exhaust leak. Is your turbo manifold cracked or is there just a leak in a gasket or something? If it is the turbo manifold yes the best way to go is to weld it. but more than likley the crack will keep spreading thats why a cast turbo manifold is the best way to go.
Old Feb 25, 2007 | 12:25 PM
Scion Noics
i have the links to the pics up as to where it is, sry i would post the actual pics on the post but i cant fig out how to do it lol, its not a crack or nething, its where i guess the sealant that they put in that pipe has "unsealed" itself and is now leaking im not sure what the actual piping there is called but its the pipe that runs off the wastegate and into the downpipe? i believe thats it, sry still learning what exactly everything is called lol, also if neone can explain how to put the images on the post itself i would greatly appreciate it and will do so right away lol.
Old Feb 25, 2007 | 12:32 PM
BBScion05's Avatar
Oh okay now I see the problem it, its the dischare pipe of your wastegate to the exhaust system. If you plan on leaving the kit on the car and not removing it often I would def weld it. If not I think you could get a good coupling that could kinda crimp the two pieces of metal together, kinda like a u bolt clamp. But If I were you I would def have it welded. hey your the same guy from the other post i just answered. haha
Old Feb 25, 2007 | 12:40 PM
Scion Noics
yeah thats me :D i jus got the kit put on friday so now im jus trin to get everything worked out and runnin right lol. and the axel back and this leak are really the only 2 probs i have lol, once i get these taken care of ill be good to go . i appreciate ur help lol, im gonna go ahead and weld that shut tomorrow and also go pick my exhaust up and put that on and be good to go lol.
Old Feb 25, 2007 | 12:44 PM
BBScion05's Avatar
Good luck man the turbo kit looks like it is built very well. I noticed the turbo manifold is cast. Which is great for reliability. Anyways if you have any further question just post em up or PM me. Happy Modding.
Old Feb 25, 2007 | 08:54 PM
satoman44's Avatar
dezod kit. ya, i had the same problem. i had the whole dump tube cut off and had a one piece pipe welded into its place. when did you get your kit btw? they were supposed to redesign it a while ago.
Old Feb 25, 2007 | 09:04 PM
Prototype_xB's Avatar
There's a leak there because the dump tube off the wastegate to the downpipe is a "Slip-Fit" exhaust pipe. No perfect seal. Why dezod built the kits like that is beyond me, but as i told ya i used a product called "thermal steel" which goes on as a paste, and hardens to seal exhaust componets. It crusted off after a while i assume due to the higher EGTs from F/I.
Old Feb 25, 2007 | 09:06 PM
He got the kit from me, and i installed it. Dezod has redesigned the downpipes. Paul PMed me last week tailing me the new DP's are available.
DaBlackBox
134
Apr 10, 2022 02:04 PM
eric29
15
Apr 26, 2016 07:27 PM
Andreas24
May 17, 2015 09:05 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
