FIC Issues Need Help - UPDATE PG 2. HELP!
I understand that personally I'm going to have to agree with it having something to do with the ecu but sometimes if a sensor or something goes bad after the tune it willl cause major headache but most likely the auto eco is throwing something off with the tune.
But I still wanna know who tuned the car cuz I'm lookin for someone I have a good guy local but other options r good too
Sidekick 4G
Sidekick 4G
Mike will always be my tuner. Car runs good. Just need resistor mod. Gas mileage is WAY up. Took a whole tank to get to otown and only 3 quarters on way down.
Car is running now - i reset ecu.... but i do need the auto relay mod because i hear the buzzing after car is off still. so i have to unplug FIC for now when i park. Also need the resistor for the 5k hiccup at WOT. Hopefully the issue doesnt come back from keep unplugging and plugging fic in.
Ohhh ok yeah mikes too far man n not only that almost impossible to contact I mean but I may still go to mike just cuz my car runs great with mikes tunes but I got a local guy here that works with aem n he tunes great so I may give him a try same price as mike but on dyno n I've seen aot of his work very reputable as well
Sidekick 4G
Sidekick 4G
pretty sure my ECU just fried... i plugged in the FIC and put car in ON position and heard a LOUD POP. all the sudden theres smoke near my driver side window and near my gloved box. Now Neither FIC will idle at all, car revs up by itself and then shuts off..... fml.
Ok so i just put in Manual ECU. On the FIC i just purchased the RPM's still fluctuate when key is in ON position.... no idea why it does this. I am still using auto harness however. Car wont start still. It cranks but wont turn on. Tried putting the old FIC on - It turned on went to abou 1500 rpm and shut off immdediately. Tried connecting the stock ecu up and same result. I am lost and not sure what to do. Should i put that auto relay in the harness and cut the gear selector wires? I have a feeling something else is wrong with the car.
Negative, the Ignition key system thing is located behind the dash above the pedal assembly it runs off the dash harness not engine harness, you have you do the paper clip trick, the only difference between auto and manual engine harness is one extra clip in the engine bay
these could go bad randomly? the car was running for 2 weeks. went and got tuned on new FIC... had to keep unplugging FIC when i parked because i dont have the auto relay in the auto harness so the battery would drain. and one day i plugged it in and turned car in On position before cranking and POP! smoke everyhwere.... no idea what happened but now car dont work
Risen_Son_Racing
Mar 14, 2008 09:59 PM
