Gaskets or Hi Temp RTV
gaskets....hands down
rtv if and only if its an emergency. iv done it before when a gasket was damaged and waiting for a replacment. rtv will eventually burn and exhaust will start leaking. depending on how flat the mateing surfaces are rtv will work for a little bit.
i was told to use the copper RTV when using the rtv as a gasket. because the rtv will burn away, but then there will be a layer of copper that will basically make a gasket.
side note: i'm running gaskets on everything though
depends honestly...think about v-band exhaust systems, they do not require a gasket. turbonectics kits when they first came out for the tc didnt have a downpipe to turbo gasket that came with the kit (if i remember correctly). There are some industrial flanges that are precisely machined so no gasket is needed. Ill look for a link to post up.
here is an example of large scale gasketless flanges
http://www.dimnp.unipi.it/santus/Pub...oli/2009_3.pdf
In the Turbonetics kit in particular (coming from 2 years experience with it) it did not require a gasket between the turbo and downpipe. Red RTV worked flawlessly for 2 years but from the manifold to the turbo it came with a metal gasket. I never had any leaks from my kit anywhere. If I had a choice, I'd go with a gasket though.
