Greddy turbo q's (i know)
#43
krdshrk, I'm working with ucyib2papi on his car. if you can, send me the cd iso and I'll get it installed. I soldered the e-manage up. Basically all connectors are soldered up, however I didn't put the e-manage directly in between the ECU and the engine harness (it's just using input, not output at the moment). I even suspected bad ground point for the e-manage so I moved ground to a known good ground point and tested voltage from the +B with my multimeter, tested fine. I'm beginning to think that it's a bad unit.
I also have not intercepted the MAF signal yet either, so in it's current stance the car is drivable at 15mph.
As for the injectors, I think they are wired correctly. The car ran for about a half hour at idle and in reverse to put it back in the garage.
#46
light came on so that was a huge positive. now has to resolder some points and then hopefully its all gravy baby.
i dont know where that came from, sorry. im just so excited i dont have to send it back
#47
#49
ok, so after about a yr of tryin to get this done....
still not done
so since i didnt have a show to go to got the wire harness from anotehr se member, not dezod, sorry
gonna use that today and hope that ch2 responds and the cel goes off and i can finally drive my car.
anything i should know on this harness as in changing something or another
i know nothin, and have failed at life :D
still not done
#50
CEL won't go away but when car is done and running, drive over to a auto parts store to read the CEL codes to make sure it's just the missing cat error. You may also want to go there once a month or so just to keep a good eye on it.
Hydryman
02-23-2016 03:35 PM
