Guy on CSTC claims 426whp on 12.5 lbs...
Originally Posted by CarbonXe
Originally Posted by B_Real45
Yes, Carb you are correct.
Not to mention his built head was only limited to stock 6200 redline as mentioned in one of his posts (response to my question).
I definitely see a BS flag on the horizon.
Assuming you know the true VE of the engine at given rpms.
that's the hardest part of the formula. I've used this tool for years.
But then again, if I do the formula and give him a 105% VE, he's only flowing an extra 70 CFM. And that's saying that he has one of the most efficient heads ever made.
Originally Posted by SoFloTC
i already called it. hence why the post is made. rob stop picking on me and giving me attitude because ur car isnt tuned man, if ur mad at luiggi or dislike him dont take it out on me. not cool. btw he said hes tuning ur car this upcoming week.
I was laughing because if the things you posted...
You posted that you thought dyno'ing in 4th gear was weird.. and didn't know why he did it.
You then "corrected" Marcelo for something that he didn't even mean... hence why I was asking if you were drinking... more of a joke than anything.
And yes my car is tuned.. tuned by me. Go ask Luiggi if he tried to use an OBD-II scanner to tune my car.. cuz he didn't and yet he was trying to tune my car in closed loop. Also ask him how he didn't know what to say when I asked him about modifying the injector response time.
lol, you've got some growing up to do.
A tuner that says he doesn't tune a system because it's not worth it is saying that because he really doesn't know that particular system.
I don't doubt Luiggi's abilities on Cobb or Greddy, but from personal experience, not F/IC. Why would a tuner even attempt a tune without an OBD-II scanner? Btw, don't you realize there are more Greddy maps floating around than F/IC? That makes a tuner's life easier.. he can copy one, make small changes, and charge you for a full tune.
I chose the F/IC because it's what I wanted.. and I'm glad I chose it because I'm able to tune it and learn more about tuning in general.
I'm curious about your tune Rob. When I was street tuning, I tried the all 0 O2 map and tuned primarily off the fuel map and the car didn't like that too much (mostly idle/vacuum was freaky). It would be perfect for a while, then out of nowhere I'd get an insanely lean idle, boost would sometimes go too rich, etc... After I got tuned by Toan @ PTuning, I realized that the O2 map was the way to go. It's basically just set a value and the F/IC will automatically aim for that AFR.
I don't really feel like getting into a big thing because I want to go to bed, I'm just saying that it didn't work for me without an O2 map, and with the O2 map, my car is running flawlessly.
^^ I noticed that too.. that's what didn't make sense to me and that's what got me started playing around with injector response time.
At first, I left things default - the 486us in the setup. After doing the correct calculations for fuel trim, and leaving the O2 map zero, the car stalled every time.
As I got closer to the true value of my particular injector's response time, the car idled better and better with O2.
See the logic is you shouldn't have to have any O2 skewing under normal driving (no boost). Let the stock ECU keep the AFR near 14.7. This is how my map is right now. My injector response time is 1100us and my O2's are 0 under vac. Car idles great and drives great. There are still cells I need to adj but it's hard on the street without a load-bearing dyno.
I know how much it totally sucks ___ to start all over, but I say just go ahead and use the O2 map lol. It makes things SOOOO much easier. No joke, my vacuum is almost all 3.01's and my fuel trim is all -25, and I cruise at ~14.5, I idle at about 15 (I changed the idle O2 to 3.05 to lean it out a little more).
I would like to add that I do have an O2 map.. it's just 0's under vac.. but I have it targeted for specific AFR during boost.
This really helps in tuning. I still want to mess with it more and more to perfect it.
Originally Posted by m6ar2cel6oTC
so what your saying carbon is just set like lets say 11.5 afr on boost and thats it? or you have to minus timing and still mess with the fuel trims?
Timing is a completely different story. Timing is where the power is really made, not in the fuel trim. You'll only see about a 5HP difference between an 11AFR and a 12.5AFR. Don't pull enough timing and you won't make much power, pull too much timing and kaboom.
There isn't all that much power to be made from tuning. Tuning is more about making the car run reliably.
btw he really does have that much power i can vouche for him and plenty more people from the island here can vouche, he does run 14 psi on the street and his motor is not stock his motor is fully built. his turbo in fact is a 60-1 not a 60 trim w a full 3" turbo back exhaust
if it helps he knows what he is doing, check out the thread on here for 2nd gen xb he built a custom kit on it and making great numbers ( https://www.scionlife.com/forums/viewtopic.php?t=257497 )
Chad Marcelo is saying 60-1 FTW because both of you have that turbo and it's bigger than the OP on clubsciontc.
