HELP...dash lights flicker (electrical)
Old Feb 25, 2012 | 10:41 PM
troy2003's Avatar
Default HELP...dash lights flicker (electrical)
Ok, here goes...the car won't start quit a bit, when I shake the negative battery terminal hard it seems to help the car start. Once it starts it runs fine until it gets hot in the engine bay, then things go nuts, every two minutes or so while driving all dash lights flicker for a millisecond and the car stutters hard also for a millisecond. Other times when the engine bay gets quite hot it will go haywire with the dash lights going nuts and the car sputters to a stall. I'm forced induction with an Odyssey slim battery and many many many other performance mods, so any info anyone needs to help please please ask...p.s....I've done a quick look over bay wiring and nothing seems glaringly wrong.
Old Feb 26, 2012 | 12:44 AM
trd07tc's Avatar
list your grounds
Old Feb 26, 2012 | 12:49 AM
PeArLwHiTe07tC's Avatar
Test ur alternator. Maybe the internal voltage regulator took a poop. Idk. Lol
Old Feb 26, 2012 | 02:17 AM
troy2003's Avatar
Originally Posted by trd07tc
list your grounds
List my grounds???....you list em!!!!!....lol. all grounds are stock minus my sub ground in my trunk....ill double check that.
Old Feb 26, 2012 | 06:55 AM
trd07tc's Avatar
just trying to help w/e not my problem
i bet you clean all your grounds you solve your problem
Old Feb 26, 2012 | 11:23 PM
troy2003's Avatar
Fixed, please close. Fix was: the shop I had swap my clutch out, I'm guessing, raised the bell housing back up after clutch install...mounted bell housing and didn't realize the forgot to connect the negative battery ground on the housing...and there is no way to get to it without removing the starter and in my case, intake pipe and blow off valve. With that said I think they got lazy and hand tightened it cause it was loose, so I removed the before mentioned parts, tightened the ground down and all good as it stands now, consistent starts, no dash flicker and good boost when the engine is running hot.
Old Feb 27, 2012 | 12:47 AM
trd07tc's Avatar
your welcome
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
GoodVibes
Mar 10, 2015 04:29 AM
xa007xa
Feb 22, 2015 03:05 PM
MonsterunderBed0
Feb 17, 2015 08:42 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
