help! slim FANS
is that specs true? on the site its only 900+,
http://www.mishimoto.com/mishimoto-s...or-fan-12.html
permacool 12" draws 1200 cfm at 3000 rpm.. mishimoto couldnt possible draw 1200 for 2000rpm and their blades ares similar
i had to set up 2 12'' slim fans due to fitment problems with my zpi kit i have a question as far as pull/push had to mount one in the front of the condenser. how do u switch the fan from pull to push do i just switch the wires or do i take the fan off and turn it around? cant seem to find this info anywhere
well, now that summer is here, i am nervously watching my water temperatures on the scan guage. it can heat up if i'm going to slow in traffic. saw temps up to 212 degrees before i lowered them by turning up the heater and blowing the fans to tha max. glad i can have the windows down.
well, i have the TRD thermostat, so i should run cooler, but i just worry, don't want to boil over in traffic. i'll have to ask p-tuning i guess what they say. maybe get a custom radiator shroud and fans if it seems bad.
^^ I usually see heating issues on watercooled turbo on a slow traffic, long idle scenario.. Is your turbo water cooled?
fans in front of the condenser you should set as pushers.. Switching direction of air flow you can do by changing the polarity of your power wire and in some fans requires you to flip the fan blades. Some fans though are exclusively pushers or pullers
well lets see..
whats taking up more space?
1) stock radiator with stock fans and shroud
or
2) Koyo radiator with Spal fans medium profile ? ( Ptuning people have the same fans)
or
vi3tb0i09
Sep 23, 2015 08:32 PM
