Hole in Intake Manifold
I recently just put in my stock injectors, (running NA for a bit until the weather calms down), and i noticed a tiny little hole in the intake manifold underneath the center bolt for the intake manifold. my car (NA) as of now has been idling at 19 vacuum on a cold start and when its warm its at about 19-20. could that tiny of a hole cause that much of vacuum loss??
dumb question for fun...HOW THE HELL DOES THIS HAPPEN?!?!?! LOL
-20 is around normal vacuum. one easy way to check if its a leak. start the car and sray some brake cleaner around that hole. if your car revs a lil when you sprayed then its a leak. but since your n/a i dunno how in the hell you got a hole if it is a hole. maybe you just had a faulty manifold
i did run nitrous on this particular manifold...but i still dont see that causing a pinhole. usually there would be a hella lot more damage than that. and thank you for the advice!!!
Greg S
Jul 21, 2016 07:28 PM
