installed ZPI stage 0 this weekend...pics included
Old Jan 23, 2007 | 02:28 AM
malibuboy54's Avatar
Default installed ZPI stage 0 this weekend...pics included
i just installed my ZPI stage 0 kit this weekend with my bros and friend....i'm the tan asian guy! man was this a headache to get everything right, but in the end, was worth it like no other!
http://www.4tecko.com/images/scion/
Old Jan 23, 2007 | 02:37 AM
tonytc05's Avatar
Vaccum hose should go to the side of the waste gate not the top. BOV should face the other way.
Old Jan 23, 2007 | 02:38 AM
OuterHeaven's Avatar
Intresting... is your wastegate not connected properly?? I know that is not the same as my Tial but the Tial connects to the other port. Also did you not have the right tool for HKS blow off valve clip?? I could help ya out with that if thats the case. Hit me up if you need any help and welcome to the tC boosted family. ZPI FTW!
Old Jan 23, 2007 | 02:57 AM
Whocares05050's Avatar
Welcome to FI, and congrates on your kit.
ZPI FTW = ]
Old Jan 23, 2007 | 02:59 AM
i had the vacuum line connected to the bottom of the wastegate before...we tried switiching it and all of the sudden the turbo started working....yeah, i couldn't get to the store to get the tool to do the blow valve ring, haha...so i had to improvise.....does it matter which way the bov is facing?
Old Jan 23, 2007 | 03:05 AM
yamaha16bw's Avatar
Nice pics. Its going to be hard to keep that engine bay clean though. I would have some kind of a dump tube made for the wastegate dump.
Old Jan 23, 2007 | 03:09 AM
yeah, i heard the open dump will make the engine pretty dirty....was thinking of fabricating a tube for it.....i'm assuming this would change the sound...?
Old Jan 23, 2007 | 03:16 AM
yamaha16bw's Avatar
prolly but with it facing up like that....Your going to melt a hole in the heat shield on the hood. Thats like 1,500 degree heat coming out of there...sometimes hotter.
Old Jan 23, 2007 | 03:19 AM
well right now, the wastegate is dumping downwards i believe, cause we had it the other way first, and it fried some of my hood insullation, but now, no heat damage....didn't really use any instruction cause they were all bad, but anyone with pics for this kit would be helpful...i'll search first though
Old Jan 23, 2007 | 03:22 AM
shadow12one's Avatar
does anyone know how hard is to install a Dezod S1 turbo kit yourself?
Old Jan 23, 2007 | 03:24 AM
oops, sorry guys, i put pictures in with the wrong wastegate setup....this was the testing stage pics, the actiual vacuum line does run on the top part and not on the side...we tried the other way and got no boost, but switched it to the top and got boost...haha, my bad, didn't even look at the pics i posted, lol
Old Jan 23, 2007 | 03:31 AM
clayisland485's Avatar
I just took the flange zpi gave me, got a muffler shop to weld on a dump tube and bolted that to the wastegate...then decided it was just too loud and took the downpipe and got a close dump welded on. As far as the clip for the BOV, you can go to any auto parts store and get a special set of pliers that will help put the snap ring in
Old Jan 23, 2007 | 03:35 AM
yamaha16bw's Avatar
Depends if youve ever done anything like it before. If you have never worked on cars before I'd pay someone else to do it. I installed both of our kits and I had never done a turbo install before but Ive been building dirtbike engines and working on cars for a few years. Took my about 6-8 hours for one kit by myself.
Old Jan 23, 2007 | 03:39 AM
this was my first turbo build, and it wasn't too bad.....the thing that took the longest was the oil pan on my kit.....also, making sure you have a wide array of tools, etc makes the process go by much quicker....if you don't really do mods to your car by yourself, wouldn't recommend doing the turbo either...just too much room for error
Old Jan 23, 2007 | 04:06 AM
I took 3 years of auto shop class in high school. I completely tore down and rebuilt a mustang 5.0 engine, tore down and repaired whatever the hell a dodge caravan has, custom fabricated a new brake line, installed a few things around the engine, shocks, springs, installed systems, thats just what i can remember.
Im definitely no expert but i do have a little bit of experience working with cars.
Old Jan 23, 2007 | 04:21 AM
yamaha16bw's Avatar
You'll be fine then^^^
Old Jan 23, 2007 | 04:24 AM
I put my Stage 0.5 zpi kit in with the help of myself and I ....definitely do-able, P.I.T.A but can be done
Old Jan 23, 2007 | 09:54 AM
MrChoyBoi's Avatar
Nice kit Just dont get pulled over.
Old Jan 23, 2007 | 11:58 AM
ERIC-TC's Avatar
I noticed the oil-return is installed on the side of the pan instead of the front. In one of the pics you are taping the oil-pan then on the other the oil fitting is welded instead. What's the deal. Looks good you have any pics of the oil return line routing?
Old Jan 23, 2007 | 03:08 PM
rhythmnsmoke's Avatar
Music City Scions
Just curious on why you mounted the WG upside down, and the HKS BOV backwards? You said you fixed that now, so take new pics, and upload them directly to the thread.
PS...good job by the way. How does she drive? What gauges do you have for monitoring?
