Its ALIVE!
Old Jan 27, 2010 | 05:34 PM
  #761
RusWolf's Avatar
what do you by brace ? i'm not sure what that is..
Old Jan 27, 2010 | 07:05 PM
  #762
m6ar2cel6oTC's Avatar
Ptuning is selling there manifold!!! If you don't want to have a Custom made one.
Old Jan 27, 2010 | 07:08 PM
  #763
cburglb34's Avatar
yev i have just the thing for you....
http://cgi.ebay.com/ebaymotors/CAST-...Q5fAccessories
Old Jan 27, 2010 | 07:21 PM
  #764
SoFloTC's Avatar
^ he already posted that
Old Jan 27, 2010 | 07:42 PM
  #765
DezodDon's Avatar
Yev, a brace, like brace your self in coming.
You weld a brace on the down pipe so you can bolt it to the engine. This way the down pipe, turbo, manifold and engine are one unit. By doing this and putting a flex at the pivot point of the engine you effectively isolate all the parts we are talking about. You can do it now with your current setup and add a flex and wouldn't have to worry about a crack ever again.
Old Jan 28, 2010 | 09:52 PM
  #766
RusWolf's Avatar
^^ Sounds interesting Don, do you have a picture of how it should look ?
Yeah i dont think i'm buying new manifold, my brother is goiung to weld my current manifold, we are going to weld in flex pipes and try to do what Don is saying and run the car at 20psi.. dont need more then that.
i hope i can just get a better idea and possible a picture of how bracing looks like.
Old Jan 28, 2010 | 10:04 PM
  #767
Ace83's Avatar
Ronin Scion
Originally Posted by RusWolf
And one more thing, Vinny really does not like those 900cc ptuning injectors, he said they dont open and close fast enough on low rpm and he think if we had 700-750cc injectors we wouldnt have this problem.
going back into this post, do you know what injector response settings (ohms) did vinny set on your map.. also did he set your injector lag specs on the trim map on the hydra, those could affect opening and closing of injectors when not set..I just got the ptuning 900 specs ill prolly will setup when i get to it
Old Jan 28, 2010 | 10:08 PM
  #768
^^ ace I got injectors for you 750cc let me know what you can offer.
Old Jan 28, 2010 | 10:12 PM
  #769
Ace83's Avatar
Ronin Scion
already got some ptuning 900ccs
Old Jan 28, 2010 | 10:20 PM
  #770
RusWolf's Avatar
^^^ Ace i honestly didnt know about that therefore i didnt ask these questions you mentioned.
now question to everyone, anyone ever heard of a company Godspeed ?
they seem to be producing fans and high performance radiator fo us.
but i'm leaning towards SPAL fans and Koyo radiator.
Old Jan 28, 2010 | 10:28 PM
  #771
Ace83's Avatar
Ronin Scion
ok cool, the car is still with vinny right? you can check it out yourself later
Old Jan 28, 2010 | 10:34 PM
  #772
RusWolf's Avatar
no the car is home and i'm in Kuwait enroute to Baghdad for another 6 month.
once my manifold is fixed, new radiator and high performance fans will go in as well and then retune and finished map will follow with 7.5K redline and traction control and launch control dialed in as well.
12 psi daily driver and 20 psi pump gas race setting. so by the time i'm back at the end of summer/beggining of fall the car should be 100% ready as far as tuned and reliable colling system and manifold. Only few thing will be left to do, wider tires and LSD and thats it i will be good for a while.
Old Jan 29, 2010 | 01:42 PM
  #773
LunchBoXB's Avatar
Originally Posted by Ace83
Thats a pretty interesting radiator posted not sure about quality.. the only problem with the mishimoto is that plug, all you need to do is teflon it enough and thats it. With the difference in price vs koyo, i would still rock a mish rad.
Going back to this post... Did you see there new drain plug? Apparently, Mishimoto heard about the issue and went ahead a release a newer drain plug. I was reading that if you send them an E-mail, they'll be able to get a new one out to you if your current one leaks.
Also, I was reading your thread here, and saw this.....
Originally Posted by thendawg
This is the radiator I plan to go with - apparently this brand is really catching on and make some awesome radiators - btw one really "cool" thing is its a 3 row vs the stock single row - and as far as I know the mishi and the koyo are 2 row.
http://cgi.ebay.com/ebaymotors/Mizu-...Q5fAccessories
Then, this guy said...
Originally Posted by ecko04
Nothing is wrong with the Mishimoto Radiator
Do we understand that Mizu is a knock-off of Mishimoto?
OP, awesome thread, just finished reading through it. Good luck with the build!
Old Jan 29, 2010 | 02:44 PM
  #774
crush02342002's Avatar
stay safe yev!!!
Old Jan 29, 2010 | 02:47 PM
  #775
cburglb34's Avatar
yev another tour keep safe maybe ill bump into you there sometime
Old Jan 29, 2010 | 05:27 PM
  #776
Racersky's Avatar
Stay safe man....
Old Jan 29, 2010 | 05:35 PM
  #777
paul_dezod's Avatar
Scionetics
KAD
Stay safe in the sand box Yev!!!!
Old Jan 29, 2010 | 08:39 PM
  #778
RusWolf's Avatar
Thanks for your support guys ! I really do appreciate it... its tough being away from everything you love and definately makes you appreciate little things more ! Therefor i think each and every american should get deployed at least once for a full 12 month tour.
Now comes the question:
If i get TT V 2.1 manifold, how many changes to my charge piping would i have to do ? I currently have dezod's charge pipes.
I do know i'll have to get new downpipe and s-pipe ( if i have to get new ones i might as well upgrade to 3" )
Old Jan 29, 2010 | 08:46 PM
  #779
highvoltage1's Avatar
Yev Take care over there bro! Hope to see you back here soon and safe! God speed!!
Old Jan 29, 2010 | 10:07 PM
  #780
RusWolf's Avatar
Do you guys think that rewelding dezods manifold will be as strong as new or should i just get V 2.1 TT that someone offered to me ?
How would these manifolds compare at 20psi ?
