My Build
Old Sep 24, 2010 | 06:05 AM
  #281
BlackKnight's Avatar
Music City Scions
Sweet! I bought a truck since my car isn't ready and I planned on getting one anyway. 2010 GMC Sierra 1500 SLT already bought EDILive AutoCal, K&N 63 series intake, plan on getting headers once I'm there also plan on exhaust upgrade and that is it. Hoping while I'm home to see the engine come to life with the tC
Old Sep 24, 2010 | 09:08 PM
  #282
deathbyc4's Avatar
well my tuner said i'll need to torque my head bolts down more, apparently the 65 ft lbs that ARP recommends aint enough to his standards..... guess it'll be awhile til i get around to doing that.
Old Sep 25, 2010 | 12:40 AM
  #283
trd07tc's Avatar
Please torque ARP head studs to ARP specifications
Old Sep 25, 2010 | 02:42 AM
  #284
deathbyc4's Avatar
and thats what i figured too, if ya gonna build a motor, read the instructions. I guess they are used to boosting Hondas and not Scions. Then again, my tuner has a 700whp DD RSX and his are torqued to 95-100, or so he says.
Old Sep 26, 2010 | 04:53 AM
  #285
Music City Scions
If all goes well I should see the engine in operation before I come back to work.
Old Oct 11, 2010 | 11:10 PM
  #286
mustb3ds's Avatar
X2-----3-------and----4
Old Nov 23, 2010 | 04:23 PM
  #287
Music City Scions
Progress!
Old Nov 23, 2010 | 04:26 PM
  #288
Ace83's Avatar
Ronin Scion
when are they going in?
Old Nov 23, 2010 | 04:28 PM
  #289
Music City Scions
The engine / transmission / turbo? Engine / transmission should be NLT then the end of the week. Can't wait, its been ridiculously long project, TT has a lot to blame on this one.
Old Nov 23, 2010 | 04:30 PM
  #290
DeatschWerks's Avatar
Looks like some nice work on the head and block.
Old Nov 24, 2010 | 07:24 PM
  #291
paul_dezod's Avatar
Scionetics
KAD
Better pics of the knife edge on ports?
Old Nov 24, 2010 | 07:26 PM
  #292
weezyfbayba's Avatar
sexyyyy oh btw on my arp instructions it said 80lbs?
Old Nov 24, 2010 | 08:00 PM
  #293
Music City Scions
Sorry still in Iraq, the shop sent those to me.
Old Dec 17, 2010 | 03:45 AM
  #294
Music City Scions
The B&G RS2 coilovers I have use 60mm ID springs front 180mm & rear 150mm. Stock was entirely too soft 6KG F & 8KG R. The problem is the only springs I can find stiffer are significantly stiffer. The replacement are 12.27 KG / 686 lbs-inch / 120 N/mm front & 15.33KG / 857 lbs-inch / 150 N/mm rear will these be too stiff? I want a very firm ride and will need it for the power and torque the tc will have.
Old Dec 18, 2010 | 02:56 AM
  #295
Music City Scions
There is a shortage on the springs and 150mm are being discontinued so I replaced the order with 9kg Front and 11Kg rear (160mm length).
Old Dec 18, 2010 | 02:15 PM
  #296
brett561tc's Avatar
been waiting a long long time to see this car finally run. i cant wait to see what it can do. if its good 1/4 mile times you are after, then go as stiff as possible in the rear. about 1,000 lbs spring rate should do it.
Old Dec 18, 2010 | 02:30 PM
  #297
Music City Scions
I am still looking for street driveability though, that is why I am not wanting to go too stiff.
Old Dec 18, 2010 | 02:42 PM
  #298
brett561tc's Avatar
how about having a separate set of coils for the rear on track days. im sure you already know how much easier the rear coils are to remove and install then the fronts. unless you have some custom speaker box in the way.
also it would be nice if someone made some sort of spacer/shim that fit in the rear coils to prevent the back end from squatting on a launch. that way you could just throw it in at the track.
Old Dec 18, 2010 | 02:46 PM
  #299
Music City Scions
Too much of an hassle, I have adjustable struts so that may help with the street. I'll keep testing different combos
Old Dec 18, 2010 | 03:04 PM
  #300
brett561tc's Avatar
well i can tell you from experience that just getting 400whp to the ground in a tc is not easy, even with an lsd. you are going to have to sacrifice comfort quite a bit if you want to come close to even realizing half of your cars potential performance.
