Need to run rich on idle after install Turbo
Old May 25, 2018 | 09:42 AM
taoybb's Avatar
Default Need to run rich on idle after install Turbo
Hi, I'm having problem with idling, I installed a turbo and using my local brand standalone ECU and having problem that the car need to be running quite rich on idle to be drive-able.
Now running AFR around 12, I tried to get it to 14-15 but it will cause engine to stall.
The ECU run just like a open-loop style, No MAF, No O2. Injector is 550cc and running a bit higher fuel pressure (43.5psi on vacuum hose on).
Thanks
Old Jun 7, 2018 | 03:45 PM
xile6's Avatar
What standalone are you using?
Sounds like its incorrectly tune. And are you using a map sensor?
if not using a map sensor and not using MAF. That's your problem.
Old Jun 9, 2018 | 01:54 AM
taoybb's Avatar
It's local brand, name 'KKT' (only well known in my country, not really on intl).
I do already use MAP sensor, a Toyota 1.8bar. not really sure what car it came from.
sleeperTC07
May 7, 2013 01:13 AM
victor123897
19
Jan 15, 2013 02:12 PM
FamilyCarXaLV
23
Jun 26, 2011 08:21 AM
DeAnzaJig
Dec 31, 2010 12:30 AM
MillerRS1
27
Sep 1, 2010 01:59 PM
