Not getting full boost???
I found that it leaks boost.. im not sure if anyone has tested that for leak, if you look at its just a rubber so the fitting that connects to the brake booster line will seal.. but there is no clamp to it, just a grommet that creates a semi tight seal.. its like just connecting a tight hose to a vacuum port without any clamp or zip tie on it
lol the boostcontroller are hiss too no soap needed but best of luck
try looking for it aorund injectors the insulator
^^ depends on boost controller, truboost solenoid did not leak anything even with soap and water.. depends if its a normally open or closed solenoid. bc it leaks when it needs to control boost.. And the leak is loud and whistles, thats is something you dont want to ignore.. imagine when you try leaking air on your tires valve stem
rvascion
Nov 12, 2020 03:23 AM
Klashan
Sep 24, 2015 12:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
