The Official F/I - HP / Dyno Thread
Old Mar 14, 2008 | 03:56 AM
  #241
Mr_Meaty's Avatar
Nice numbers!
Why the big difference between the 2 runs?
Old Mar 14, 2008 | 03:58 AM
  #242
20tCDude05's Avatar
He prolly used 175 shot of NOS. LOL, J/K. Seems like he went from Supercharger to Turbo. Haha
Old Mar 14, 2008 | 12:56 PM
  #243
unvdistc's Avatar
Originally Posted by Mr_Meaty
Nice numbers!
motor swap.....first run was with no tune at all....49th run was after hours of tuning. finally got it where we wanted it.
Old Mar 14, 2008 | 12:58 PM
  #244
unvdistc's Avatar
Originally Posted by krazylowgsx
dam Eddie... your cars still running? lmao!! just playing man.... bout time you get back on SL
Yeah still running great! I'm going back there next week to tune with......well you know........ Should be over 300.... we will see.
Old Mar 14, 2008 | 01:42 PM
  #245
Mr_Meaty's Avatar
so you had the same turbo on during that first run? Or was the first run all motor?
Old Mar 14, 2008 | 03:09 PM
  #246
unvdistc's Avatar
Yes everything was the same from the first run to the second. I literally drove it from the shop to the dyno with no tune to tune it. The map that was on the emanage was all screwed up so i new the numbers would be low. we just needed to know where to start. We cut that run really short due to the fact that it was not safe on the AFR.
Old Mar 18, 2008 | 10:02 PM
  #247
army11b's Avatar
Default .
I just dynoed my car today,, did 220whp and 210tq. zpi stage 0 with full 2.5' exhaust, walbro fuel pump, 550 injectors and emanage ultimate, the dyno/tuner guy said that there was a lot of heat soak because of no IC,,, of course,, but im hoping to get the Turbotoyotas ZPI ic/piping kit once they come out with it. Hopefully ill post the dyno sheet tonight.
Old Mar 23, 2008 | 08:05 PM
  #248
redrumtc's Avatar
Strictly Scionized
nice #s
Old Mar 23, 2008 | 08:09 PM
  #249
redrumtc's Avatar
Strictly Scionized
How much boost?
Old Apr 13, 2008 | 02:57 AM
  #250
760sciontc08's Avatar
at 8.3
294 hp
  #251
oh ya dezod s1 kit
08
Old Apr 14, 2008 | 03:27 PM
  #252
Mr_Meaty's Avatar
damn...tq is "Off the charts" huh!
Old Apr 15, 2008 | 04:49 PM
  #253
just alittle bit
im tunning it down tho
Old Apr 17, 2008 | 12:10 AM
  #254
redrumtc's Avatar
Strictly Scionized
new #s for my turbo set up 8psi 308whp and 295lbft
Old Apr 19, 2008 | 04:37 PM
  #255
miss_tc_tuner's Avatar
Very nice. Any word on the Megan midpipe. I either need it and a tracking number or my money back asap. And my private messaging is not working so you may want to email me at lailk16@concord.edu. Thanks.
Old Apr 19, 2008 | 05:27 PM
  #256
t_urbo_C_harged's Avatar
Originally Posted by digduged
Anyone know of a 5 speed transmission gear upgrade?
I am trying to research the Final drive swap out of a Camry transmission... The only problem is that it is a gear made onto the output shaft of the transmission, so you would need to get that whole shaft (assuming it will fit into ours, that is what I am trying to find out is the deminsions) and you will also need to do the change the ring gear on the differential. This will essentially give us "longer" gears, but the only difference between the Camry trans and our modified tC trans would be the 5th gear, which shouldn't need to be swapped since it is on the outside of the case. Our fifth gear would be more usable.
I would like to experiment with this when I have enough money to do a quaife LSD as well, along with a new clutch and flywheel. So when I order the TT kit I have been looking at and the quaife, look for a post from me stating if it will work or not.
Old May 9, 2008 | 04:40 AM
  #257
StanceMotorsports's Avatar
nice
Old May 22, 2008 | 03:57 PM
  #258
enjoithis's Avatar
08 tC runing Dezod S1 Turbo @ 8.5psi , full 2.5" catless exhaust. AEM F/IC Tuned by Ripp (Engine stumbles over 6k rpms)
(Need a better tune)
Old Jun 23, 2008 | 06:00 PM
  #259
rhythmnsmoke's Avatar
Music City Scions
The problem with that is, you will make the car slower.
Old Jun 24, 2008 | 02:27 AM
  #260
army11b's Avatar
Default .
Got 265whp 260tq on 8psi with my new ic and piping kit from turbotoyotas, will try to scan dyno sheet when i go to kinkos to make copies of dyno :D
