Oil Return Question
Originally Posted by yamaha16bw
I would ask for a completely new turbo. Something isnt right. Just so I understand more of what your saying. You think the oil return line is backing up and forcing the hot used oil in the turbo? If thats what your saying I dont see how thats possible. Maybe I got it wrong though. Have you called Kenny at ZPI to see what he says?
You said in a earlier post you were getting smoke out the rear exhaust? Is it white or blue? Does it go away after the car warms up or doesn it get worse as you get on it?
BTW, The smoke is white.
Do you have any pictures of your current setup?? Have you tried to remove the line to see if there was a lot of oil build up inside?? Also I assume you have been checking your oil level for your car but I know when I had my problem I was a quart low.
Yeah check the oil level. Spraying oil out the exhaust isnt good. Odd though if your burning oil the smoke should have a blue tint to it. Why dont you try and rebuild the turbo yourself since it seems turbochargers.com doesnt want to help. Are you sure that the oil is coming from teh turbo and not the motor. Have you taken off the manifold to check?
You could send your turbo to have a second opinion... Blouch is very respectable in Rebuilds.
http://www.blouchturbo.com/upgrades/
Originally Posted by tCtCtC
wait for it.....
BACK FROM THE DEAD.
i have the same exact problem. my line isnt touching the DP at all and i dont think its backing up either.
kaeon- did you ever find a solution?
BACK FROM THE DEAD.
i actually kinda want a yaris cause of gas mileage lol.
but did you find the problem for the turbo itself?
1. How low/high did you tap the oil pan? it should be as high as possible to prevent backflow to the turbo
2. How's your oil return line? there should be no kinks and always downhill from the turbo
3. How's your turbo seals? check if you havent
4. Is the car running weird or loss of performance or anything or losing oil? try doing compression test
2) there are no kinks now, but ill check it again
3) idk, i have to check the intake pipe
4) im not losing oil, but idk.... it feels the same i guess
