Oil Spurting From Breather Filter
Old Mar 10, 2008 | 05:53 PM
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by Soulquarian
^^You know what, I was just about to do a DIY on how to do a Compression/Leakdown Test. I think I will do a video DIY on it, instead of write-up.
In the mean time, you can go buy a pressure tester ($30 at O'Riely's Autoparts).
PS.....Nice Catch can setup. Is that a 20G turbine?
Yep that's the 20G.
Nioce...how much boost you running? Dyno'ed/tracked it?
Old Mar 10, 2008 | 07:12 PM
Soulquarian's Avatar
Not much unfortunately. Only 4lbs. Dyno'ed about 224whp. I was told I needed a boost controller, but now that I think about it, it's probably just the wastegate spring.
I'm going to call again and find out, if so, I'm going to get a retune so I can hit my potential and get a lot of track time at the Longo Scion Triathlon on Friday.
Old Mar 11, 2008 | 10:42 PM
What's the word travis! I need to see that vid lol.
Old Mar 12, 2008 | 02:32 PM
Music City Scions
Did you buy the compression tester. You can go ahead and do the test without my vid, as there are instructions inside the package. I'm just doing the vid for the hell of it. But give a brotha some time...LOL. I'm putting the intercooler pipes back on the tC, and buttoning everything back up. I'll do the vid when I'm done.
Old Mar 12, 2008 | 02:50 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: Oil Spurting From Breather Filter
For a while, I've been leaking oil from my breather, and now it's getting all over the engine bay. I have a ZPI kit, but I know someone with Turbonetics kit that's having the same problem in that area.
Will an oil catch can solve that problem?
Yes this is rather normal on turbo cars. The crankcase gets excessive pressure, which it can not easily vacate, so it pushes it out through the vent shaft. Sometimes this has oil in the vapor as well. A catch can or breather can will solve this issue for you.
Old Mar 12, 2008 | 04:51 PM
I'm in the process of doing the leakdown and compression test, but I took it to Corner3garage, and they say I might have a blown engine. I have a lot of vapor coming out of the oil catch can, and there's oil around the oil cap. I also gave a strong gas/exhaust smell on the cabin.
Old Mar 13, 2008 | 12:34 AM
Bad news. My engine's shot. The Compression test came back good, but the leakdown was not so positive. Apparently, my rings are bad, and that's why I've been leaking so much oil and having so much vapor coming from the oil catch can.
I was told that's a part that can't be replaced, so I have to get another one...
All because of my f$#&ing BOV and/or Air Filter.
Old Mar 13, 2008 | 01:55 AM
TurboToyotas's Avatar
Hmmmmmmm sounds fishy.....
Compression test good = bad rings.....thats odd....
Leakdown test bad = something in the head ie valve seats
What were you told that cant be replaced? And none of this has anything to do with an air filter or BOV.
Unless there is allot you are not telling
Regards-
Todd
Old Mar 13, 2008 | 02:26 AM
Regards-
Todd
Here are the results of the tests:
Compression:
Cylinder 1= 138 PSI
Cylinder 2 = 126 PSI
Cylinder 3 = 125 PSI
Cylinder 4 = 127 PSI
Leakdown:
Cylinder 1 = 25%
Cylinder 2 = 28%
Cylinder 3 = 33%
Cylinder 4 = 26%
Anyone want to post stock results so we can compare?
Old Mar 13, 2008 | 03:02 AM
Music City Scions
Regards-
Todd
If the compression test comes back good, there is no reason to do a leak down. A leak down failure can mean bad rings too though.
+1 on what part Can't be replaced?
Old Mar 13, 2008 | 03:03 AM
Music City Scions
Regards-
Todd
Compression:
Cylinder 1= 138 PSI
Leakdown:
Cylinder 1 = 25%
Cylinder 2 = 28%
Cylinder 3 = 33%
Cylinder 4 = 26%
Shouldn't the compression be higher than those PSI #'s?
Old Mar 13, 2008 | 04:31 PM
Regards-
Todd
I talked to the guys at Scion-parts.com who build motors and whatnot, and I should be able to salvage most of my block. I suppose I'd need new rings, pistons, rods, and bearings, but at least the engine would be able to withstand more horsepower.
Sucks, because I'm getting a lot of conflicting info!
Old Mar 13, 2008 | 04:47 PM
Music City Scions
Your compression should be in the 170's, not 130's and 120's. So, your compression is not good. Yeah, as long as you don't have a hole in your block, you only need to replace the inside stuff. Like you said, more power though.
Old Mar 13, 2008 | 04:51 PM
I'm going to talk to the guys at Dezod today. I really don't want to go through the hassle of going back to stock and praying Toyota lets me go through warranty.
Old Mar 13, 2008 | 05:43 PM
What would be some of the causes of having such low compression and the leakdown problems?
Old Mar 13, 2008 | 05:56 PM
Schuller's Avatar
The weak ringlands crack. It is part of the top of the piston. The pistons are designed for fuel efficiency but not for making lots of power. Compression tests are not always accurate because if the cylinder gets some oil it brings back allot of compression. For example you take the compression of a cylinder and it comes up 130 psi and then you add a some oil into the plug hole and retake the compression it will go up close to normal. Leak down tests don't lie though.
Old Mar 13, 2008 | 05:58 PM
I don't think I've ever been over 4 pounds of boost, so I was making THAT much power. Only around 224.
Old Mar 13, 2008 | 06:15 PM
Schuller's Avatar
Well it depends on what your EMS is doing to your afr and timing and how you drive it. You can easily blow these engines even with a good tune at 4psi. Ever hot box a cigarette? Too many puffs to soon and you ruin a perfectly good smoke.
Old Mar 13, 2008 | 06:30 PM
Music City Scions
That would be unethical. They won't though, they know motors just don't loose compression.
Old Mar 14, 2008 | 11:38 PM
Soulquarian -
It was nice meeting you today. Not to often I get to meet Scionlife members face to face.
Please keep me posted and let me know if I can be of any assistance.
Regards-
Todd
