possible wastegate issues??
Old Apr 2, 2009 | 01:37 AM
BC_Scion_LA's Avatar
Default possible wastegate issues??
Okay so the car was running just fine before all this started happening. one night driving normal i decided just to give it some gas to make sure all is still well with the setup. Well much to my surprise it was not. I gave it some gas and it felt as if i was trying to go fast while holding the brakes down. Boost was building but did not register on the gauge. I decided to let off and there was a blow off but not like the HKS SSQ should sound. I checked all the vaccume lines and they are all tight and connected. Drove it around some more and sounded like the waste gate was not opening like it should. I have a tial 44mm with a 3 pound spring installed. I am pretty new to boost but have a basic understanding of it. Any help would be greatly appreciated.
Old Apr 2, 2009 | 01:44 AM
08superwhite's Avatar
Did you check your intercooler piping?
Old Apr 2, 2009 | 01:48 AM
scikotictc232's Avatar
pictures ? ? what set up you running and more details on how the sound sounds ?
Old Apr 2, 2009 | 01:54 AM
gingles's Avatar
wouldnt having a blown off intercooler pipe mess his afrs all wack...well at leasts that does mine....i would deff check for boost leaks though.
Old Apr 2, 2009 | 01:59 AM
intercooler piping is fine it still is reading vaccume when i go to floor it the gauge just stays at zero and wont go into boost.
My setup is a custom setup what do you need to know about the setup
The sound is the turbo is spooling but the car will not go anywhere. Blow off just sounds a woosh of air instead of high pitch like it normally has and waste gate is an open dump and i can hear it over the exhaust and i cant anymore.
Like before it is as if i floor the car and its like driving with teh brakes to the floor also.
Old Apr 2, 2009 | 02:53 AM
ValenciaS's Avatar
WOW, same thing happened to me, I spoke with Toan at ptuning and he helped me out alot. Thats odd and i mean same exact thing. It was my waste gate, there it was stuck open a bit and I heard the turbo spooling up but no boost at all. Heres a picture. as you can see the gap there
Old Apr 2, 2009 | 03:03 AM
ValenciaS's Avatar
Also check your BOV, make sure its not stuck or leaking.
Old Apr 2, 2009 | 03:56 AM
gingles's Avatar
well there ya go....time for a new wastegate...haha....maybe your kit company will hook you up
Old Apr 3, 2009 | 01:03 PM
tcengel's Avatar
Isn't there supposed to be a ring at the bottom of the wastegate that seals that gap?
Old Apr 3, 2009 | 01:45 PM
yamaha16bw's Avatar
Thats what I was thinking as well.
Old Apr 3, 2009 | 02:22 PM
ValenciaS's Avatar
yeah there is a ring at the bottom of the wastegate but mine was pushed down so i forced it back up
Old Apr 6, 2009 | 07:42 PM
ValenciaS's Avatar
Does anyone know if TIAL wastegates have the ring on the bottom like the t-netics evolution wastegate does?
Old Apr 6, 2009 | 08:00 PM
paul_dezod's Avatar
Scionetics
KAD
A "Seat", yes they do.
Old Apr 6, 2009 | 10:52 PM
ValenciaS's Avatar
thats weired i guess the issue was not my wastegate but when i did take it off and put it back on the car started boosting fine why is that. The ring on my wastegate does close the gap i noticed that. What could It have been ?
Brammi
Nov 13, 2016 03:46 AM
my06tc
Jun 25, 2015 12:18 AM
nazblue5807
Apr 11, 2015 12:20 AM
zap-o-matic
Apr 2, 2015 07:35 PM
bushdog
Feb 22, 2015 03:04 AM
