PTUNING: 400whp Ptuning spec-ss turbokit @ 20 psi, 91 octane w/WMI 3" catted exhaust
Old Feb 11, 2010 | 12:53 AM
  #101
m6ar2cel6oTC's Avatar
probably^^^ i spray distilled water also. 60% meth & 40% distilled water.
Old Feb 11, 2010 | 01:10 AM
  #102
rhythmnsmoke's Avatar
Music City Scions
Originally Posted by Prototype_xB
Was this using the stock intake manifold?? 20psi + Plastic.....yikes
PTuning's Time Attack tC makes about 200 more hp than that and still uses the stock intake manifold. It holds up just fine.
Old Feb 11, 2010 | 01:11 AM
  #103
Mouse's Avatar
Originally Posted by Ace83
current ptuning shopping cart. total $5,566.80
Poll: Do or Not do?
I'd say if you had the means it's not a bad $/HP ratio. It's roughly 23 bucks per HP. Which isn't a bad ratio at all. That's just assuming you go for the kit that will net you aprox. 400whp. For most it's just a good chunk of loot up front for the project.
Old Feb 11, 2010 | 01:37 AM
  #104
Skratchy_Seal's Avatar
Originally Posted by Skratchy_Seal
Wow! Maybe I need to stock up on some more lol. Thanks for the tip. Are you running straight meth? I'm using Peak -20, which I think is 1/3 meth.
Ooops! I realized I read the MSDS on this wrong. The 1/3 figure was by weight. I knew that didn't seem right lol
Old Feb 11, 2010 | 01:39 AM
  #105
Mouse's Avatar
Originally Posted by ElevationTC
When you look at it, whats even on the same level?
Perfect flowing manifold
shortest in piping possible
Competely bolt on
manifold flange is steped to allow perfect sealing
comes with new slim line fans so clearance is perfect
its the sexyest turbo kit ive seen.
comes with best components possible TIAL, Garret, ptuning
3" downpipe/spipe combo
V-band downpipe
100 page install manual to make install a breeze
did i mention its the sexyest kit ive ever seen... and o yea 320whp dyno dynamics at only 12psi!
Well there is all of that ^^^ but one of the most important things is that with PTuning you've got the tuners and other people of the company fully standing behind their product as well.
Old Feb 11, 2010 | 03:36 AM
  #106
Prototype_xB's Avatar
Wow, that's suprising
Old Feb 11, 2010 | 03:49 AM
  #107
Music City Scions
It works quite well man. Why do you think there are like only 3 people on this site that have an Aftermarket Intake Manifold....lol. Cause the stocker is good past 500+whp which is more than enough for 95% of us.
Old Feb 11, 2010 | 12:15 PM
  #108
BlackKnight's Avatar
Music City Scions
I'll be in the 5% its not! LMAO!
Old Feb 11, 2010 | 01:09 PM
  #109
Well that's a relief, you just knocked $600 off my build
Old Feb 11, 2010 | 01:12 PM
  #110
Music City Scions
I'm good at 450-500whp. Anymore than that and it will be just for bragging rights.
No problem...
Old Feb 11, 2010 | 01:17 PM
  #111
It just worried me because i blew apart my plastic mani back in the day on a d17 with 14lbs
Old Feb 11, 2010 | 03:06 PM
  #112
trd07tc's Avatar
ours is reinforced with glass i believe
Old Feb 11, 2010 | 08:27 PM
  #113
PTUNING's Avatar
We ran 2+ seasons of Red Line Time Attack at anywhere from 340-550+WHP on the same stock intake manifold. It's still in one piece.
Old Feb 11, 2010 | 08:34 PM
  #114
brett561tc's Avatar
mine blew a while back...
Old Feb 11, 2010 | 08:41 PM
  #115
ElevationTC's Avatar
WTH DID U DO TO IT?
Old Feb 11, 2010 | 08:43 PM
  #116
brett561tc's Avatar
WTH DID U DO TO IT?
5,000 dry shot
Old Feb 11, 2010 | 08:44 PM
  #117
Originally Posted by brett561tc
5,000 dry shot
I know what happened.. You didint have spring bolts on your down pipe did ya!
Old Feb 11, 2010 | 08:49 PM
  #118
brett561tc's Avatar
its because of the greddy e-mangle. dont know why, but it started backfiring when i turned the key to accessories II. for those who didn't know, backfires happen in the intake manifold.
Old Feb 11, 2010 | 08:54 PM
  #119
when you going to orlando speed world.. tomrmow friday t&t 6-11
Old Feb 11, 2010 | 08:59 PM
  #120
/\/\ kinda the same happened to me, but it would backfire and blow the EFI fuse. Problem was my secondary 02 wire broke loss from it's zip-tie and melted against the block causing a short in the EFI system because those componets ground through the block.
