Retrofitting supercharger
Old Apr 25, 2009 | 06:36 PM
imsonofagun's Avatar
Originally Posted by markj113
thanks for all the info guys,
Few more questions -
1) does the supercharger require an oil feed or is it self contained.
2) does it have an integrated bypass valve or do you need an external one?
1) It needs an oil feed. The Scion kit comes with a hard line that routes to the oil pan (also included). You'll have to tap the oil pan or get one of the sandwich oil adapter like the one pictured:
Vortech does make the V3 supercharger with an oil system that is self-contained. Don't know if it will work with the Scion kit.
2) It uses an external bypass valve. The kit uses a Bosch unit just like the VW and Audi 1.8t engines. If you end up fabricating your own intake tubing, you can use what ever bypass or blow-off you want. Vortech even has blow-off valves for their kits.
Biggest thing to consider as far as bypass/blow-off valves is if your car uses a MAF or MAP sensor. If the ECU meters the air before the compressor, bypass is recommended. If the ECU meters the intake pressure, either one would be good.
Old Apr 25, 2009 | 06:41 PM
markj113's Avatar
Allready have a sandwich plated fitted for my oil pressure/temp gauges with a spare slot so can tap in to that for the feed and will have to weld a return pipe into the sump I think, here's mine -
My car runs a MAF so a bypass valve will have to be fitted too.
All good sugestions and advice, any more info that springs to mind great appreciated.
Old Apr 25, 2009 | 07:19 PM
Have you looked into the STS remote mount turbo kits? It might be easier, and haven't seen many people with one.
http://www.ststurbo.com/
Old Apr 25, 2009 | 07:32 PM
markj113's Avatar
another member looked into that system and there were a few drawbacks for our needs. Biggest problem fitting a regular turbo is the V6 engine makes the pipework an expensive pain in the ___.
Old Apr 26, 2009 | 02:07 AM
another member looked into that system and there were a few drawbacks for our needs. Biggest problem fitting a regular turbo is the V6 engine makes the pipework an expensive pain in the butt.
They have kits for single and twin turbo, depending on the application. If it's a single exhaust, shouldn't be too bad. The turbo replaces the muffler.
If you have a dual-exhaust, the setup gets more complicated. A twin turbo kit would make things a little easier, but still a little complicated.
rain7905643
Jun 13, 2018 05:29 AM
deademon
Mar 31, 2016 09:25 PM
corbinortiz
Oct 2, 2015 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
umnitza
Jul 25, 2015 07:54 PM
