s/c Rough Idle
i just got my s/c installed like last weekend, and when i start it up early in the morning b4 i leave for work (6:45am) i let it warm up for about 15 min or so b4 i start driving.
when i start it idles really low (about 450-500rpm) then it'll idle high (about 1200-1300rpm) and it will keep going back and forth.....also when it idles low, the motor seems to almost want to stall out....you know it makes that knocking sound when the engine bogs really low.
when i start moving, however, the rough idle and the low idle go away, and it idles and runs great.
is this normal? or should I take it back to the dealer?
Thanks everyone
Thanks everyone
possible vacuum leak.
also you dont need to warm up your car for so long. i usually let it warm up for like about 3 minutes, just make sure you dont hit boost before normal operating temperatures...
I dunno 450 rpm sounds really low, my s/c did this, this morning when it was a mere 58 degrees out failed to start after 4 cranks (it started then fumbled then died), and now its back in the shop for the 9th time in 11 days.. But the revving up to like 1-2k is normal.
it hasnt failed to start yet (knock on wood), but if it does i will def. be taking it in and having it looked at.
Thanks again guys
Thanks everyone
Thanks everyone
steeze69
May 24, 2021 02:57 AM
rancur3p1c
Jul 12, 2015 07:59 PM
