short block problems need help BAADD!!!
Old Mar 10, 2010 | 01:27 PM
ElevationTC's Avatar
Originally Posted by DezodDon
After reading your first post I have a few questions.
1. Did you perform a compression test?
2. If so what were the results?
3. It sounds like you are away, did you install this kit or did someone install it for you?
4. Did this problem occur directly after installation or was this a problem before hand?
5. Did you drive the car and then this problem occoured or did it occur after installation while idling?
6. Did you install your spring bolts? j/k
Some detailed info will help us help you diagnose the problem a little better
LLLLMMMMMFFAOO..made my day
Old Mar 10, 2010 | 02:19 PM
DezodDon's Avatar
thank you, thank you. Takes a bow.
So have you actually driven the car yourself yet? Or is this just stuff your friend who installed it is telling you?
Having the compression numbers would be really good right now. Let us know what they are when you find out
Old Mar 11, 2010 | 03:16 AM
gingles's Avatar
Originally Posted by cburglb34
motor is bad.... i suspect it was due to you not installing spring bolts....yup its was the spring bolts alright
dude....gtfo if you have nothing useful to post.
to the op.....we cant do anything until we know the compression numbers.
also, was it just the turbo kit? ie any new injectors etc.
did your buddy prime the oil line before connecting it to the turbo?
please tell me the oil drain line is on the bottom of the turbo and its not clocked wrong.
NonStopTuning
Jun 29, 2015 07:42 PM
my06tc
Jun 25, 2015 12:18 AM
xa007xa
Mar 29, 2015 10:28 PM
Crs22
Mar 23, 2015 08:49 PM
gularti
Dec 4, 2014 01:21 PM
