SoFloTC build thread UPDATE pg 10.
Old Aug 16, 2009 | 10:48 PM
  #321
TCpete's Avatar
Originally Posted by ElevationTC
pete what is ur HP goal?
and chad.. i have an idea.. he has a dezod mani.. buys ur turbo.. sell him ur turbo and downpipe 600.00 hes ready to rock n roll!
pete his setup will be a great starting point.. we know his turbos almost brand new!
well id like to start off with a modest 250-275 whp.. get use to driving around and how boost feels.. see how the clutch holds.. then after a while ill jump into the 350-375 range... ultimately my final goal is 5-600 whp.. but thats far off right now lmao...
yea thats why im piecing things together now.. to just to get rolling... the 60-1 he has isnt bad.. but i prefer the typical garret 60-1 or 57 trim just for now... quick spool.. full boost around 3-3200k rpms... give me plenty of top end power even on a 2.5 full pipe no cat, no exhuast... should be nice quiet on a closed dump system also.. no open dump for me.
Old Aug 16, 2009 | 10:52 PM
  #322
SoFloTC's Avatar
this turbo is good for ur goals besides the 500whp. and its 500 dollars.. like what theeee?!
Old Aug 16, 2009 | 11:18 PM
  #323
m6ar2cel6oTC's Avatar
what do you need left? just the turbo?
Old Aug 16, 2009 | 11:23 PM
  #324
TCpete's Avatar
alot of ____ lmao.. right now i wana finish some other things first before moving on to boost stuff.. need tires, new lugs, alignment small cosmetic projects.. then i can move onto boost caca
Old Aug 16, 2009 | 11:24 PM
  #325
i want good tires also lol! good street tires!!
Old Aug 17, 2009 | 12:09 AM
  #326
SoFloTC's Avatar
pete come get the turbo for 480.
Old Aug 17, 2009 | 12:22 AM
  #327
ElevationTC's Avatar
dammm just wait another hour pete.. maybe ull get it half off!
Old Aug 17, 2009 | 12:29 AM
  #328
TCpete's Avatar
word lmao ^^^^^
right now though.. tires and lugs > turbo .. i need my stance in check finally... im tired of being to high on these dam 225's..
Old Aug 17, 2009 | 01:09 AM
  #329
What are you goin for.
Old Aug 17, 2009 | 01:21 AM
  #330
if chad gets mine.. im gettin a precision 6265 ball bearing!
come on chad!
Old Aug 17, 2009 | 01:26 PM
  #331
TCpete's Avatar
what do you mean..??
Old Aug 17, 2009 | 04:44 PM
  #332
what tires are you going for is what i meant!
Old Aug 17, 2009 | 04:48 PM
  #333
TCpete's Avatar
for the moment the azenis on low pressure will be good.. once i pass a certain mark... the one mike posted are most likely what ill be using which were the sames ones i was looking at about 2 weeks ago...
Old Aug 17, 2009 | 05:10 PM
  #334
where can i get azenis for real cheap?
Old Aug 17, 2009 | 06:27 PM
  #335
SoFloTC's Avatar
:o someone buy me toyboooo so i can get the show on the road!
Old Aug 17, 2009 | 08:00 PM
  #336
toyyboo? what? your weird!
Old Aug 17, 2009 | 08:11 PM
  #337
SoFloTC's Avatar
lol
Old Aug 18, 2009 | 01:34 AM
  #338
buy mine chad.. u want my down pipe to?
Old Aug 18, 2009 | 09:01 PM
  #339
SoFloTC's Avatar
woot woot... garret 60-1 from mike will be going into my carrrrr :D also i found out why my mani keeps cracking.. i took the turbo off and wobbled the downpiped.. literally went a foot in each direction.. theres a bracket that is supposed to be connecting the dp piece they have welded on to the block.. the bracket come stock in the vehicle and were supposed to reuse this but dezod doesnt tell you, it keeps the DP from pulling down when going over bumps or what not.. so i got the bracket and also putting spring bolts on the dp and welding a flex pipe on the spipe.. theres no way this mani should break again.... mike made 360whp on 14 psi with this baby.. not expecting the same number because of my log style mani but this thing will spin all of 3rd easily on 19-22 psi.. and probably spin a 4th gear 60 roll like mike did especially cuz i got nexen tires lmaooo im so excited to get my ____ going.. should be running next week, gotta get meth installed still 450whp goal still. scared though because i have K1 rods... eeeek
Old Aug 18, 2009 | 09:05 PM
  #340
paul_dezod's Avatar
Scionetics
KAD
So long as the tuning is good, the K1 rods will hold over 500whp. Proven!
