Starting issues on rebuilt motor....
Old Aug 4, 2009 | 02:02 AM
BC_Scion_LA's Avatar
see thats weird cause we followed everything for getting the timing back lining everything back up.
Old Aug 4, 2009 | 02:08 AM
and even if it was timing i am still not getting any arc when i throw a screw driver in it. thats what i dont understand my mind is boggled lol
Old Aug 4, 2009 | 10:13 PM
Is there anyway of checking the cam sensors or crank sensors to see if they are bad besides replacing them?
Old Aug 5, 2009 | 03:26 AM
Windu's Avatar
Are you getting StatSync?
Old Aug 5, 2009 | 04:20 PM
that was my next thing was stat sync... tony at t1 told me to check it out.... i did pull up the parameters on the sync error and it was reading 1...2...3...4..and so on all the way to 10 and then started over all this while i was trying to crank the car over. I was not sure where to find the stat sync parameter on the aem...theres so much crap in that program lol.
Old Aug 6, 2009 | 02:43 AM
Windu's Avatar
Click on the tab that looks like a house in AEMPro, StatSync is in the upper right corner, then crank the engine and when cranking it should read "on" after a second while cranking. If it never changes from off to on while cranking it will never enable the ignition. It will NOT start if you dont get a StatSync.
Old Aug 6, 2009 | 06:28 PM
Okay sounds easy enough now if this is not coming on what would be causing this??
Old Aug 6, 2009 | 06:47 PM
ElevationTC's Avatar
cam sensor, crank sensor...
Old Aug 6, 2009 | 08:16 PM
DezodDon's Avatar
Chris,
You have a crank signal because I can read RPM in your log. You have one of the 3 cam signals showing up in your log but other than that you show nothing. I would check your sensor, check your grounds, check your cam timing for the hell of it. Otherwise as I and others have stated if it does not sync it will not start or enable ignition.
If you have done all of this then make a check list on paper of all the things you have done since it last ran and what you could have changed and start looking.
Check that your ignition fuse isn't burned.
Old Aug 7, 2009 | 12:14 AM
Okay well i rechcarged the battery today while at work and read yalls posts came home and did the test for the stat sync and no its not coming on.... I just checked all the grounds they are good.
Guess next thing now is the sensors. Am i gonna just have to buy new ones and throw them in to see if thats the problem cause a cam sensor is about 170 bucks which sucks or is there a way to check these sensors before buying them....
don its sounding like the cam sensor may have gone bad so i guess i will start there.
Old Aug 7, 2009 | 03:44 AM
Windu's Avatar
Before you buy a sensor check the clearance between all three pins and the sensor, and double check cam timing.
Old Aug 7, 2009 | 01:10 PM
what would be the right clearence?
Old Aug 7, 2009 | 01:43 PM
yamaha16bw's Avatar
Like Don said check the ING fuse in the engine bay as well. That happened to me and I was cranking mine for like 30 minutes wondering why it would start. Simple 15amp fuse fixed it.
Old Aug 7, 2009 | 01:49 PM
QFMFT
Old Aug 7, 2009 | 01:53 PM
the fuse was one of the first things i checked but i guess i can check it again.
Old Aug 9, 2009 | 12:58 AM
well checked the fuses and checked grounds and all is good. I pulled the cam sensor and i guess monday i will try and find a place that will have one so i can replace it and hope it starts (cash for clunkers anyone LMAO!)
Old Aug 10, 2009 | 09:27 PM
well ordered a new cam sensor from toyota today should be here tomm morning. Gonna make sure the crank sensor is good.
Old Aug 12, 2009 | 01:31 AM
well put cam sensor in cleaned all the electrical contacts and and checked the crank sensor for the hell of it. Tried to start and still nothing just cranking and cranking and cranking...... Not really sure what else to look into.
Old Aug 12, 2009 | 03:16 AM
yamaha16bw's Avatar
im still saying timing chain is off. everyone else with this problem said the same thing "im sure i did the chain right" only to find they didnt and once fixed it fired right up.
Old Aug 12, 2009 | 04:51 PM
I did pull up codes on the scanner about all 4 of the coil packs being bad. I am starting to think more and more something is off on the timing as well which is gonna suck cause gotta pull the motor back out.
