Supercharger Boost Guage
Old Jun 14, 2007 | 08:06 PM
turbodreams's Avatar
Default Supercharger Boost Guage
Hey i was just wondering why trd makes boost guages for the tacoma, tundra, and 4runner but they don't make a boost guage for the supercharged tC? when i called and asked my dealer about them installing a aftermarket boost guage if i bought a supercharger they said they wouldn't do it, and that it would void warranty. What kind of BS is that?
Old Jun 14, 2007 | 09:31 PM
Scott8's Avatar
That's the dealers first line of defense against aftermarket parts. IT's only true if the part that you installed made the car break.
I can't see a boost/vac gauge making a supercharger blow up. Probably prevent you from pushing it too hard.
Old Jun 14, 2007 | 09:33 PM
thats what i was thinking...... i mean they make a boost guage for the tacoma, 4 runner, etc but if anything i think being able to know my a/f, boost, etc would only prevent some of the problems with the s/c
Old Jun 14, 2007 | 09:37 PM
equinox2355's Avatar
well to be honest they would have to do more than just a gauge install... they would have to modify the intake manifold and install a MAP sensor for the gauge to work. Since our cars use MAF, a "boost" gauge cant read off of that.... Just FYI
Old Jun 14, 2007 | 11:32 PM
ah, thank you. So are the superchargers that they have for the trucks different? because if they can do it for them i dont see why they cant do it for us. Good info tho equinox, thanks
Old Jun 14, 2007 | 11:41 PM
satoman44's Avatar
could always use an aftermarket gauge which all contain an internal map sensor. there's nothing stopping you from using a boost gauge. all you have to do is tap into a vac line.
Old Jun 15, 2007 | 04:11 AM
mahalzkita28's Avatar
yea... i have a boost gauge on my s/c... just need a t-fitting and tap into the existing vac line.
Old Jun 17, 2007 | 01:29 AM
SpeedDeamon's Avatar
Default Re: Supercharger Boost Guage
my local stealership said they'd install my autometer gauge....but they want a $100 ____ that
Old Jun 18, 2007 | 07:35 PM
cessblood's Avatar
TRD said you can use aftermarket Boost gauge and it will not void your warranty. They had it posted on their website when the supercharger first came out.
Old Jun 18, 2007 | 08:03 PM
Simplyscion's Avatar
Team No Limitz
if you want to use the TRD boost gauge just buy the one for the tacoma or tundra and just use that...thats what i did for my supercharged tC.
Old Jun 18, 2007 | 08:13 PM
Thank you everyone for your feedback, i really appreciate it!
Old Jun 19, 2007 | 10:50 PM
2_much_tc's Avatar
does it work the same? how did you go about hooking it up?
Old Jun 20, 2007 | 02:40 AM
mriches's Avatar
A boost gauge hooks into the vacuum system. It displays the amount of vacuum or boost pressure on that system.
The vacuum system is run off of the engine, and is tandem with the intake pressure after the super- or turbo-charger. So, all you need to do is measure the air pressure there to measure your boost.
It's not going to require anything more intense than inserting your own vacuum cable in the system somewhere, with an extra nipple on it for the boost gauge.
If you want the boost gauge to light up, the light must be wired up to your light switch. If you want it to be installed "correctly," you must splice those cables. A dealership may not take issue with this if you do so according to code. This can also be done without any soldering by sticking a cable in between some connectors, if you are feeling sneaky and aventuresome.
rain7905643
Jun 13, 2018 05:29 AM
corbinortiz
Oct 2, 2015 02:45 PM
MisterSkiz
Sep 27, 2015 10:25 PM
crimson_sinn
Sep 25, 2015 09:41 PM
JonathonK
Sep 22, 2015 07:27 PM
