Supra Turbo on a tC
Old Sep 19, 2006 | 05:26 PM
tC9o9's Avatar
the 05-06 header will fit on the 07, so i would make a safe assumption that the 05-06 turbo manifold would to.
Old Sep 19, 2006 | 06:46 PM
DriveEuro's Avatar
And you're doubting Dezod's post? They DO manufacturer turbo kits. I'd imagine they would know.
Old Sep 19, 2006 | 06:57 PM
Nick06tC's Avatar
Im not doubting Dezod, but from the looks of it, the header did change but if the block did not change, a turbo manifold would work on an 07.
Redesin of a header doesnt mean redesign of the exhuast ports on the head.
Old Sep 19, 2006 | 07:03 PM
Joe_Dezod's Avatar
The runners of the manifold changed, not the flange. 05-06 turbo manifolds will work on the 07.
Old Sep 19, 2006 | 07:27 PM
XD40tC's Avatar
You should just order a kit from Dezod and call it a day. But have fun anyway!
Old Sep 19, 2006 | 07:40 PM
Joe_Dezod's Avatar
Thanks man! haha
Old Sep 19, 2006 | 07:52 PM
BigPinoyTC's Avatar
im assuming you plan on boring the head to get a higher rev point. Bekuz if you dont you will hit that rev limit so fast you wont even really be able to get the full use of the turbo. I have a slightly larger turbo then people have seen from ZPI and Dezod and i hit boost at about 3500 and within a sec im having to shift. Only gear you really enjoy it is really 3rd.
Old Sep 19, 2006 | 09:01 PM
3min3m2's Avatar
i wish i had a dealership like that around here....
good luck with that, i believe you can make it work...possibly even a TT setup...would be difficult, but do able..
Old Sep 20, 2006 | 12:04 AM
JUMBO's Avatar
N.G.S.O.
I figured that since boost would come on so early (due to the Supra's first turbo spooling up so early) that I wouldn't have to raise the rev limit.
Wouldn't boost be present from around 2K, maybe a bit less?
Old Sep 20, 2006 | 01:16 AM
Joe_Dezod's Avatar
With running only one of those turbos on a tC motor you should be able to hit about 4-5.5psi at 2000rpms. That's a good amount in my book. This is in a higher load gear though (4th and 5th). I'd say that in 2nd gear you'd hit peak boost before 3000rpms.
Old Sep 20, 2006 | 02:43 AM
kungpaosamuraiii's Avatar
C'mon, man up and use both turbos!
Old Sep 20, 2006 | 03:04 AM
3min3m2's Avatar
I'd trust Dezod on what they tell you...they know what they're talkin about.
That would be a mean set-up for a bottom end tC....not much top, but you could get off the line easy
Old Sep 20, 2006 | 02:01 PM
tC_litigator's Avatar
but the tC already has enough low end with a n/a setup...wouldn't you want a set up that has more high end for drivability purposes?
Old Sep 20, 2006 | 04:32 PM
3min3m2's Avatar
you can always use more in anywhere...bottom or top...
just a nice bottom end would be a great demo car....everyone would be like "holy cow that thing takes off quick..."
Old Sep 20, 2006 | 05:43 PM
It'd be more like, "Holy cow that thing will burn through its tires for days before moving more than a a yard or two."
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
mxwes
Aug 30, 2015 09:11 PM
