TRD Supercharger/Weapon R intake/NST Pulleys/computer tune
Re: TRD Supercharger/Weapon R intake/NST Pulleys/computer tu
Originally Posted by blackbeast
I need some suggestions for retuning the computer for all of the mods I am about to do. I have the TRD supercharger and NST pulleys installed. I am getting a Megan Header, down pipe, and Weapon R intake made for the supercharger. I have been told that I need to worry about my engine running lean with all of the mods I have planned. Is anyone running this set up with the TRD reflash for the supercharger? Does anyone have so direction for cheap ways to reprogram the computer to maximize drivabilty and performance?
My comment regarding "Suckas" rubbed some of you the wrong way. Sorry I hurt your little feelings. Crank, Pistons, performance cam, springs I guess I should have been a bit more clear. I too have had the supercharger for a while. In fact I am on my 2nd one as the 1st one blew. I will post the numbers and I know that "the shop" is the real deal. Check them out they do great work. theshopct.com.
Thanks to all who contributed to my choice of the AEM from Scionlife. For of rest of you just wait and see what happens over the next two weeks. Pics and specs to follow.
The header, down pipe, and intake are installed. The new supercharger that replaced the one that blew has a new lock on it, and a special working on it so that if you can figure the lock out you are still screwed if anything goes wrong. I have not been able to find a solution to getting the lock nut off that will not hurt more than help the situation. I ordered the AEM F IC but needed a harness to make the job easier which is another 300 bucks. Now I don't have the money to get the computer installed right away so I am right back where I was with a car that is limping around with strange responses to all the air from the intake. And frankly the down pipe makes it so f ing loud that I am kinda ____ed I did it. Guess I'm the sucka now.
this kid..or should i say GUY doesnt know sh*t, boosting on a budget=fail, and thinks the s-pipe is making his car extremely loud=more fail, and claiming he can gain so much power from a SC while others tell him he cant=even more fail. all in all ur out money and ur out of a car. huge waste and then u called every1 on her suckaz cause u think u know a thing or two about a thing or two.
going to "the shop" in Norwalk CT. They are a great shop, and yes you can pull those kind of numbers with the right mods. FYI - I already have updated springs, pistons, and crank so my engine can take it. I'll post the dynos for all you haters out there.
Suckas!!
Suckas!!
LOL jus want to quote this post he made bc it makes me laugh when i read it.
guess were haters but haters that know alittle more then u.
"suckas" what a herb.
i made 250whp and 220tq (i think) with meth,9.5psi, intake,mmw header and draxas exhaust tune on greddy eman. ult. if that helps also i live in new jersey... and same tuner as icenine or the scion tc sc that made 311whp
you only made 250 and 220tq? and you have meth and cams?
when i was s/c and running 10.5 lbs with megan header,zpi racing exhaust, hks cold air intake and 2 step colder plugs and i made 270whp and 253 tq. with a conservative tune. you should be making a lil more since you do have cams. what cams do you have? how come you did your pistons and not rods? and what did you do with the crank?
and if you get the harness for your fic you wont need anyone to install it. its really easy. take the glove box out and unplug your ecu and plug it to the harness and then the harness to your ecu. all the plugs go in there right place you cant put the plugs in the wrong place because they wont match up so its dummy proof.
ColonelSanders85
12-09-2020 09:44 AM
airmankevin1
02-14-2018 01:23 PM
TheTripleC
01-04-2015 06:46 PM
