Treadstone Test Fit Issues
So I started test fitting the parts to see if everything would fit together alright. I'll grant that I'm not that mechanically inclined but but from my experience (as limited as it may be) if I'm gentle and don't use tools I should be ok. So the kit comes with a cast iron manifold and after screwing in some of the bolts the threads all flaked out. I have 1 stripped for the wastegate and 1, maybe 2, stripped for the turbo mount. So I have two questions.
1. How can I fix this?
2. What did I do wrong so I don't do it again?
Also I was just assembling the mainfold, turbo, wastegate, and downpipe on a bench. Not in the car.
WTF??? arent the treadstone manifolds cast iron??? seems to me like the threads on the bolts would strip before the bolt holes. unless treadstone qc didnt catch something and the manifold came that way.
Originally Posted by Schuller
Next time hand tighten the all the nuts and bolts then torch them to spec. You can take the whole assemble to shop and they will help you out.
Btw, thanks for pointing out the obvious. lol
Are the threads on the bolts stripped or the actual manifold?
Iron is pretty hard to strip with your bare hands..
Did the bolts come from Treadstone? I've heard they use Chinese C grade hardware sometimes..
Treadstone has a habit of sending out bolts with the wrong pitch, they also don't thread the manifold down far enough and ussually leave gaps...I'll have more info for you later tonight bolts and their pitch and whatnot
Btw, they did this to me on three seperate occasions with three different applications
I've heard really the issue with Treadstone is their customer service.
Sometimes you need to replace parts for a customer - and I think they would be better if they did that without complaints.
worst case scenario you could re-drill the holes 1 step bigger and re-tap them for a bigger bolt... is the tapped hole a blind hole (can't see through it) or is it all the way through?
if you decide to go that route it's important to get the right type of tap (bottoming tap if it's a blind hole), and take your time so you dont break the tap off in there.
oh also for the piece that mounts to the now-stripped holes, just use the same size bit to open up the hole a bit.
*make sure to look up a tap drill bit chart so you know exactly what size bit to get
awdmofo
Feb 8, 2016 05:58 AM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
gyiu
Regional - Pacific South
12
Feb 20, 2015 04:20 PM
