turbotoytas simple kit+GT3071R (vid p 12, final results p 31)
FWIW, a few days ago AEM tech support told me that z1.07 works better than z1.04. The tech stated that 1.04 worked best when they first tested with the TC a few years back but when they developed their PnP harness, they retested and found that 1.07 worked better for them. YMMV.
Also worth noting is that 3 weeks ago AEM revised their wiring instructions for the crank and cam sensor grounds from intercept to tap. The new FIC/6 instructions can be found here:
http://forum.aempower.com/forum/inde...c,25388.0.html
so that goes for all PNP harnesses? or the one AEM developed? is it different from the one that i got from boomslang? was the tuning done on a same year tc? could it have been a difference between an 05-06 and 07 and up model tc?
iv never had anyluck with the z107hex....i have tried 104 on 2 2006 Tc's and 2 2007 tc's...so far 104 has been better. 107 seemed to make the cars throttle response lag more and made idle vary. also it would make a car die at a stop sign because of this poor idle.
tommarow ill do a vid for you guys.
I wonder how this new wiring instructions will affect tuning.
I trust more whats on the aem forum than i do tech support...thats just me though.
http://forum.aempower.com/forum/inde...c,19962.0.html
they still havnt changed the information...but if youll look at page five a guy with a 09 tc used 107 and says he likes it...
oh boomslang added the cam and crank resistors to their new harness's and added a 3rd resistor... on the o2 leads... on Hix (aka kyle) we blew that resistor and it threw the car into open loop. just thought id give a heads up if some of you have gotten a boomslang harness and notice an extra resistor.
maybe idk...never seen it work well..
btw flintmica was tuned by turbochargers using 107....I admit the tune they gave him sucked royal ballz (no maf map, no 02 map). i swapped to a base map of mine and it didnt change a thing really, car acted the exact same till i changed to 104. after that it was easy tuning from there.
but hey to each his own...if you can tune using 107 or 110 more power to ya. I still want to see a perfectly running tc using 107 and 110, maybe ther is something to it. im just running off of what i have tried and what is proven.
As for the wiring change, Boomslang tells me that they have always tapped the - crank and - cam wires, contrary to AEM's old instructions. As far as I can tell, tapping should be less likely to pick up induced electrical noise than intercepting the grounds and running them 6' to the FIC and 6' back to the ECU unshielded. I can only guess that AEM changed the wiring to reduce the noise problem that often necessitated the installation of resistors between the + and - FIC inputs.
The only thing I'm 100% sure of is that my new Boomslang PnP harness doesn't work. When installed I get a P0335 CEL and the car is undriveable. Boomslang, Descendant and Dezod are all aware of the problem, it affects more gen2 XB owners than just me and they are working on a solution. Boomslang just informed me that they have ruled out a software fix and need my harness back.
As for the wiring change, it shouldn't affect the tune. It should only reduce induced signal noise on the crank and cam sensor grounds at the ECU by shortening the ground path.
There are a lot of things I'd like to try but I don't want to void my harness warranty so I'm sending it back to Boomslang today, at their request.
i know that (the reason for the resistors)...lol...perhaps the resistor is burned out...did you check with a multimeter? thats one of the codes we would get with the old boomslang harness before they used resistors. thats why a bunch of us started putting resistors on em our selves.
funny thing is there was a rep from aem on the boards a couple of months ago and when i asked them if they were going to add the resistors on their pnp fic's for the 05-06 Tc he didn't know what the hell i was talking about.
Boomslang just emailed me a shipping label so I'm gonna ship it back and let them figure it out.
Edit: FWIW, my XB2 harness doesn't have resistors on the O2 leads.
To the OP, sorry bout the threadjack.
well im out of ideas...lmao..
wireing is fine, sensor is fine, resistors are fine....not much left to check except for different fic and harness...maybe a pin on the harness is a little loose or a wire is loose.
hey cory what was that guys screen name that sent me his fic for repair? I remember him saying that he talked to you quit a bit about his xb2. I just cant remember his damn name to save my life...lol
uggggg lol lets see ummmmmmmm i know mach box is turbo and one other guy that has a white one i cant member his name for the life of me either hmmmmmmmmm and sinnce the new forums suck its not in there but it was a white xb witha custom kit hmmmmmm
