V2 Return Fuel Setup...
This system is all you will need to make 500+whp with the right sized injector and/or engine management.
at 60 psi base pressure im already running out of room at 16 psi had to keep my redline at 6400 from 7500 have alot of head work bc stage 2 cams dw 700 cc injectors i say get 1000cc injectors and this fuel return kit and 500+ safe?
port and polish head, s/c 12 psi , pushing 14psi with ported head, water intercooler, alphaworks header , weapon r intake manifold, weapon r intake, 9:0:1 compression. emanage ultimate. im running 550 , with 255 fuel pump. i was looking to upgrade my emanage ulitmate and fuel system. for full stand alone and bigger injectors and possible fuel return system. the last time i had it tuned over at church automotive i hit 375hp with 91. but if i had a stand alone with better or bigger injectors with fuel system kit. who knows .. maybe 400?
I knew that was comeing...this is just my personal opinion but i do beleave there is more than just "its a dynapack". Id have to crunch a few numbers and research some specs but i dont think the trd s/c can flow enough air at that psi to support that kinda power.
just curious but has anyone gotten a base run before boost at church's?
this has just been bugging me but i got to ask it and im sorry if it rubs anyone the wrong way, I really dont mean it to, but isnt church's the same place that someone had some baseline runs on a tc2 that made more power than what it is advertised as from Toyota, also in order for a car company to advertise an "SAE" power rating it must follow specific SAE guidlines?
anyone have a base run from churches using a stock tc1? please post up if you do, Id love to compair with what i have. I really would like to know exactly what is going on. I really cant grasp how my dyno runs on a dynapack differ soooo greatly from runs done at church's even if you consider all the variables. even when compaired to other dyno's im still on par with them when variables are considered. I have gotten runs in on other dyno's and still the numbers are close hp wise.
in anycase this just proves one should worry about power gained between stock and boosted on the same dyno on similar days. that will give you a better idea of direction to go and how the mod/mods have changed the output and performance.
just an idea but take a look at the dyno thread and you may see my point.
