Washing engine bay
Old Jul 22, 2008 | 10:36 AM
paulky_2000's Avatar
Yes, Let's see it now!
Old Jul 22, 2008 | 02:45 PM
Ace83's Avatar
Ronin Scion
Originally Posted by Blue_TC_Man
Originally Posted by Mr_Meaty
I thought if you sprayed cold water on your hot engine block it would crack...no?
I would make sure you COMPLETELY dry off the center and impeller side of your turbo, as it will rust up real bad...my impeller side is coated, but my center section is not and it's rusted up now.
if you block cracked from some water hitting it youd be screwed everytime you drove through a puddle, only thing you need to worry about when washing an engine is getting the distributor wet if you have an older car with one
the motor can take some abuse but rapid drop or increase in temp on any metal in not good... it will weaken the metal bonds after awhile.. its the same principle as warming up the car before you drive hard..
aen pics!!!
Old Jul 22, 2008 | 04:49 PM
Mr_Meaty's Avatar
so, ace, what is the solution? drive to the car wash, sit for 15 min in the bay, wash my engine, sit for another 15 min and then drive home?
my engine bay gets HOT!
Old Jul 22, 2008 | 07:20 PM
Ace83's Avatar
Ronin Scion
I dont know yet lol, solution is to get a house and do it on the driveway before driving the car.. what im concerned of spraying water on the hot manifold and turbo, it boils water like crazy.. I guess stock is fine due to the manifold heat shield and it doesnt get hot that hot
Old Jul 22, 2008 | 08:29 PM
Mr_Meaty's Avatar
well, that's how I have done it...park in the street, wait till teh evenning, wash, wait till the next day and pull it in teh garage...but I don't have a power washer at home...
Old Jul 22, 2008 | 08:53 PM
GQQSE13's Avatar
u'd have to worry about the alternator and battery though correct? ( i just need to not be lazy n wait for it to cool off an dwipe it all down)
Old Jul 22, 2008 | 10:27 PM
I don't know about all this.....
There are FAR too many sensitive connections under the hood of a modern automobile. I would rather spend a week with a Q-tip than a month wondering why my car won't run after spraying it down....
Old Jul 22, 2008 | 10:46 PM
Ace83's Avatar
Ronin Scion
^^ Its been done by many without problems, the engine bay can take water.. some even pressure wash it, though not recommended
Old Jul 22, 2008 | 11:07 PM
CDogbert's Avatar
I'll pressure wash my engine after degreasing it. I cover up the negative terminal and my intake filter, though. Haven't had any problems.
Old Jul 22, 2008 | 11:17 PM
crush02342002's Avatar
I have cracked stock cast exhaust mani's before by just going through a large puddle without a splash guard and have cracked the heads on a chevy lumina doing the same thing but with splash guards(big puddle.....lol). I learned to stay away from puddles.........lol
However iv owned a 87 oldmobile cutless and loved to drive as fast as i could through puddles, i even sprayed the ish outa the engine bay with water hose and about 10 cans of foaming engine degreaser, never had a problem with it. but that car also had an all iron head and block. the lumina did not.
Old Jul 23, 2008 | 12:40 AM
I'd still be very careful spraying water in an engine bay.....no matter how many times you got away with it without issue.
Just a word of caution.....that's all.
Old Jul 23, 2008 | 01:05 AM
JL56TC's Avatar
I dunno about the block cracking but I can Guarantee if your manifolds is hot it will crack and turbo stuff isn't cheep
Old Jul 23, 2008 | 01:58 AM
coryjames's Avatar
i just washed my engine day today i fried my alternator cracked my header my block my car wont start and a midget kicked me in the nuts
today was the 100 time i have sprayed out my motor and nothing happened so who knows
Old Jul 23, 2008 | 02:09 AM
lol nice core
Old Jul 23, 2008 | 02:10 AM
Dude....it happens....
I'm glad you've been lucky, but telling people it's okay to do that is like saying running across the highway blindfolded is safe.
Old Jul 23, 2008 | 02:44 AM
coryjames's Avatar
lucky i am not i know you dont blast straight into a alternator its common sense and a quick mist wont hurt nothing every time you drive through a car wash your hole exhaust system and motor gets sprayed including your radiator does it crack
Old Jul 23, 2008 | 03:08 AM
Syldrin's Avatar
You're supposed to wash your engine with HOT water. i just use the "tire & engine" setting at the car wash. and pop my hood and blast away.
Old Jul 23, 2008 | 03:40 AM
Mr_Meaty's Avatar
there's a tire and engine setting?
Old Jul 23, 2008 | 10:35 AM
I think we're all agreeing here, just expressing it in different ways.
YES, you can spray off a dirty engine/engine bay.....as long as you're VERY careful about it.
Old Jul 23, 2008 | 10:42 AM
most car washes have it, its normally a green crap that you can spray using low pressure from the wand. works good on tires, but i could have sworn alot of them have a warning post that says not to spray directly to painted surfaces.........idk i cant remember
