Wastegate Not opening.
I was doing some street tuning on my tC and had my wife doing the driving. She was doing a pull and I watched the boost gauge clime to about 15psi(It was fun but horrifying at the same time too). I have a 7psi spring in the Wastegate and I have never had any problem with it opening. I was doing some street tuning yesterday and never had an issue. I checked my vac lines and they are fine. On the way back I stepped on it and it went to about 9psi and I just stopped. What should I check on the car? It is a TiAL 38mm, vac line is from a block to the side port.
Man i just fixed my buddys like that and he had a pinched vac line (he installed the line under the valve cover cover lol) .......7psi spring should make about 6 lbs on ur gauge.......pull ur wastegate apart and make sure everything is good
No boost controller, it is just ran off of the spring. It ran just fine friday then saturday it doesn't. If you look above a few posts I have a link to a video of the WG.
Took the wastegate completely off. Valve was stuck to the valve seat. I took the handle of a screw driver and tapped it loose. I cleaned the valve and seat with brake kleen. Seems to be doing fine now. I have no clue why it did that. Just had a ton of carbon build up.
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
