Zpi stage 1 vs turbonetics kit.
you can have you tuner make a map for cold weather, warm weather, daily boost, race gas boost, drag boost curve, autocross boost curve, road race tuning, etc and store them on your laptop or PDA. You Bluetooth into the EMS, upload your new map and away you go. No trying to dig and find the interface port.
There are many more features that only a tuner would use that are also in the Unichip but suffice to say it far exceeds the Emanage in included options.
How much dyno time is that to program that many maps?
TimmyT.. Turbonetics is planning on going for CARB for this kit so I don't think that CARB certification should sway your opinion. If Turbonetcs can't get CARB, GReddy won't either.
What should sway your opinion though is that the GReddy kit includes a tubular manifold that's way nicer than the log you get with the Turbonetics kit.
What's swaying my opinion is the Unichip. I can get a different manifold..
Not sure about stage 1 but stage 1 but stage 0 spools up extrimely fast. You get power right after stepping on gas if you launch from dead stop. Comparing to most other turbo cars I played with, my scion has the smoothest power delivery for aftermarket turbo. I'd like to try turbonetics kit but I doubt it is going to be any different from any other t3/t4 setup on a TC. Hope BB option and tuning makes plenty of difference.
Yes I finally found some when I googled. Sad to say though that kit was shown at the 2004 SEMA show so if Greddy had some plans to produce (it was shown with the RX-8 kit) they should have released more info by now. It's doubtful Greddy would release the kit with that manifold as well. At least from what I've seen they usually do some form of cast manifold similar to the Turbonetics one for their kits. Although it may not even be a point of argument since they do not appear to be pursuing production very much.
Originally Posted by chubster41
damm thats nice!
also how u guys know so much about turbos?..damm i wish I need as much
i've tried to find sites but never could find any to explain it
Team No Limitz
damm thats nice!
damm thats nice!
I emailed greddy a few times about thier kit.
The first repsonse was they are waiting to see if there is enough interest in the kit to develop and produce it.
the 2nd response was they were not going to produce the kit unless they got a carb certification and it still had a respectable performance gain.
The last response I recieved was they didn't have any specific pricing information, but to expect the kit to be available @ the earliest in summer 06.
It is from this information that I based my posts about the greddy kit and the CARB certification.
CARB certification (being a californian) is very important to me. Especially if I am spending 5,000+ Dollars on top of the already $20,000 in the car I am going to put it into. Only to be able to use it for 4 years, and then Have to spend the time to remove/reinstall the kit just to be able to drive the car with current registration. And then if I want to sell or trade in my vehicle I'll need to remove the kit or sell it privately.
Being of military mind, even though I may not agree with them, rules are ment to be followed. I believe its an integrity issue. To me personally it doesn't matter if Johny Law doesn't know my car is illegal. I know its illegal, and that is enough to deter me from purchasing any aftermarket part. Be it a performance part or cosmetic.
Turbonetics = 244whp - - - -$5,595 - - - 8psi
ZPI Stage 0 = 230whp - - - $2,670 - - - 6 psi
ZPI Stage 1 = 300 - - - - - -$4,500 - - - 9 - 10psi
Dezod = 244whp - - - - - - - $3,975* - - - 8.5psi
*Without Options
*Without Options
One of the draw backs I see to using the 18G turbo is unless something has changed Greddy uses conventional sleeve bearing turbos. Typically the boost threshold time on this turbos is higher then with a ball bearing design. This basically means full boost later and depending on how they have it setup could be less of a linear power delivery.
I disagree with the greddy mani being sexy. Look at the runners on that thing none of them are the same length so the flow would be wierd and probably cost a few horses. But thats just my opinion.
