* tC : Gauge Cluster LED Conversion Guide by LEDmod.com
Old Jan 20, 2012 | 09:51 PM
  #201
kwarmbier2442's Avatar
So if the resistors I had bought were the correct ohm and everything just the wrong physical size would they still work to replace the old ones?
Old Jan 20, 2012 | 09:58 PM
  #202
sebascolombia91's Avatar
If you can fit them, then I suppose they would still work.
Old Jan 20, 2012 | 10:45 PM
  #203
engifineer's Avatar
The physical size determines the power capacity (wattage) they are rated for. Depending on which resistors you got and the resistance rating of each, i can tell you if they will work.
The reason reusing the solder is bad is because the flux (which is what cleans the joint) burns off when you solder. So the old solder will tend to pull in contaminents which are not removed if thatakes sense.
Old Jan 21, 2012 | 05:47 PM
  #204
If you go to digikey.com and type in the part numbers that I ordered it should give you the specs.
Part numbers
311-43ARCT
311-680ARCT
311-560ARCT
311-430ARCT
311-130ARCT
311-330ARCT
311-470ARCT
And I figured out that I did burn up some of the LEDs so I have the gauge working all blue now I just want to find out if I can use these resistors cause I want to make it brighter.
Old Jan 22, 2012 | 03:09 PM
  #205
And if I'm not mistaken the resistance of them should be the ohms which is the number that follows "311-" in the part numbers. Also when putting the LCD screen back on the HVAC I must have had the solder on some of the prongs touching so the display shows all kinds of weird stuff. Is the LCD fried since I have plugged it in like that or can I just clean it up and have it work fine?
Old Feb 25, 2012 | 05:05 PM
  #206
LEDmod's Avatar
Your LCD is fine...
Old Mar 6, 2012 | 08:00 AM
  #207
mrjtang's Avatar
super sexy thread!
Old Apr 13, 2012 | 05:22 PM
  #208
skeeter04's Avatar
Just wanted to show how my gauges turned out. The needles are a light purple, which looks really cool, cuz i didnt tear them apart to paint them. I scraped off the stock paintand used the purple vinyl! Sorry for the cell pic, it was dieing so i didnt have time to mess with settings
Old Apr 17, 2012 | 02:57 AM
  #209
LEDmod's Avatar
Came out very nice!!! if you paint the needle white, it will make the needle glow brighter..
Do you mind if I use the picture??
Thanks..
Old May 5, 2012 | 07:04 PM
  #210
LEDmod's Avatar
Bump
Old May 6, 2012 | 11:29 AM
  #211
ThisDudePaul's Avatar
How much for just center tach conversion?
And what are your "hours" like. Can you do weekday evenings 8ish in Fullerton?
Thanks
Old May 6, 2012 | 11:32 PM
  #212
LEDmod's Avatar
Thanks
We charge $50 for the center tach conversion
See the detail from here..
http://store.ledmod.com/index.php?ma...products_id=41
We are appointment based, as long as you make them ahead of time, we can schedule you in...
I have a shop in Anaheim now...
Old May 8, 2012 | 08:21 PM
  #213
LEDmod's Avatar
Bump
Old May 10, 2012 | 01:44 PM
  #214
TotalChaos's Avatar
I want to change my gauge faces. I read through the procedures in the beginning of this thread but wanted to know if just the face swap is fairly simple or more extensive then I am thinking? Is the needle "reset" necessary? Also, does it come with a complete instruction manual. Thanks for your help!
Old May 10, 2012 | 03:58 PM
  #215
LEDmod's Avatar
Gauge face replacement is simple..
Calibrating the needle is required, since you need to remove the needles to replace the gauge face..
Thanks..
Old May 10, 2012 | 05:32 PM
  #216
TotalChaos's Avatar
Awesome! I am going to try to order one with the TRD logo on it....I appreciate the help!
Old May 11, 2012 | 06:29 AM
  #217
Corruptelegancex's Avatar
Anyone In the long island area willing to do a Pink LED conversion for Me Message me, well talk prices :3 Super excited about my new used tc shes gotta be cute.
Old Jul 31, 2012 | 07:28 PM
  #218
LEDmod's Avatar
If you can't find anyone locally, you still have the option to send it out over the mail to us..
We have easy removal guides and 1-day turn around service...
Thanks..
Old Jul 31, 2012 | 09:18 PM
  #219
skeeter04's Avatar
Sorry I never responded to your post Sean. Yes u may use the picture of my guages.
Ive seen the pic of the all pink guages, it looked hot! Id love to see some pink and whit ones! Please post some pics when u get them done!
Old Aug 3, 2012 | 09:31 PM
  #220
FreedomPenguin's Avatar
Private messaged
