* tC : Gauge Cluster LED Conversion Guide by LEDmod.com
Old Jan 9, 2009 | 07:24 AM
  #61
LEDmod's Avatar
Resistor effects only for the speedo, tach, gas/temp gauges..
For the warning lights on the bottom, it doesn't matter what color you use..
Old Jan 9, 2009 | 09:02 AM
  #62
Iceman04503's Avatar
Default Re: * tC : Gauge Cluster LED Conversion Guide by LEDmod.com
I had a question about this picture:
I was just wondering about the labeling of the fuel and temp LEDs. But isn't the fuel LEDs on the right and the Temp LEDs on the left? And one more questions, if i want to use a white LED and a red LED on the Fuel which of the resistor should i change? Any chance you can tell me how to do the color changing needle?
Old Jan 9, 2009 | 03:00 PM
  #63
FM08TC's Avatar
AWESOME!!!! THANKS!
Old Jan 9, 2009 | 03:11 PM
  #64
CarbonXe's Avatar
[img]https://i21.photobucket.com/albums/b284/seanyiya/Scion/tC%20LED%20Conversion%20Guide/Gauge%20Cluster/tC-GaugeLEDConv-11.jpg[/mg]
The picture shows the two gauges backwards. Fuel is right, Temp is left.
Old Jan 9, 2009 | 10:08 PM
  #65
LEDmod's Avatar
http://i21.photobucket.com/albums/b2...LEDConv-11.jpg
Sorry my mistake on the labeling.. but it shouldn't make any difference in installation.
But you shouldn't be using two differe color LED on single series..
Are you trying to make the color changing needle?? if this is the case, then that is not the right way to do it..
Old Jan 9, 2009 | 10:15 PM
  #66
Akrylic09's Avatar
lol i gave up on the whole color changing needle effect....i couldnt figure it out after countless attempts...
how much would you charge to just change out the resistors in the HVAC? i already did the led swap and have the resistors in hand cause i thought i was going to be able to handle it as i did with the cluster.....but the size of the resistors kinda made me not want to go for it....
Old Jan 9, 2009 | 10:32 PM
  #67
I think i'm going to give up on the idea of doing a color changing needle too. The resistors on the gauge are they just soldered in like the LEDs?
Old Jan 9, 2009 | 10:41 PM
  #68
LEDmod's Avatar
It should be $30....
Old Jan 9, 2009 | 10:42 PM
  #69
LEDmod's Avatar
Yes...
Old Jan 9, 2009 | 10:53 PM
  #70
RICANTC's Avatar
1UP Crew
great write up! now I can re-do my needles on my own
Old Jan 11, 2009 | 01:12 AM
  #71
Does it matter which way the resistors are soldered in? Like how the LEDs you need to have it facing a particular way. Oh and am I also replacing both R155 and R157 with 331 (470 ohm) instead of 331 (330 ohm)?
Old Jan 11, 2009 | 03:45 PM
  #72
LEDmod's Avatar
Resistor has no direction... so it can be either direction..
It will work, but you'll get very slightly uneven brightness, if you have manual....
Old Jan 11, 2009 | 04:01 PM
  #73
sinningxlove's Avatar
Default LED's
anyone one in NJ able to do this?! toms river area.
Old Jan 11, 2009 | 04:35 PM
  #74
LEDmod's Avatar
Default Re: LED's
I travel to NYC often and I offer installation service....
If you don't mind driving to Flushing NY..
You can PM me your contact information..
Thanks
Old Jan 15, 2009 | 01:29 AM
  #75
Just got the resistors you sent me. Thanks alot.
Old Jan 21, 2009 | 03:55 AM
  #76
Aurora's Avatar
Post pictures peeps!
Old Jan 21, 2009 | 04:03 AM
  #77
heres mine. https://www.scionlife.com/forums/vie...494&highlight=
Old Jan 21, 2009 | 05:20 AM
  #78
YouSparkle's Avatar
Originally Posted by tCvera
anyone in south florida that would do this??
second on that. I need someone in South FL to do this on my tC
Old Jan 21, 2009 | 05:34 AM
  #79
Domo's Avatar
nice
Old Jan 22, 2009 | 07:19 PM
  #80
LEDmod's Avatar
If anyone can't fine local installer, you can always send it over the mail for installation service..
I offer 1-day turnaround..
