* tC : Gauge Cluster LED Conversion Guide by LEDmod.com
Old Jan 23, 2009 | 12:45 AM
  #81
krisimpossible's Avatar
Awesome write up LedMod! I made a howto vid of the soldering process http://www.youtube.com/watch?v=NqNJR...e=channel_page
I hope this will help some people who are hesitant to try this on their car...it's not hard! If you watch the vid and REALLY can't bring yourself to do it (and you're near LA), message me.
Old Jan 24, 2009 | 04:10 AM
  #82
Iceman04503's Avatar
I'm having some problems with my swap. The gauges won't light up. Everything else lights up but the gauges. The LCD screen turns off when the headlight turns on. Could it be the resistors?
Old Jan 24, 2009 | 06:28 AM
  #83
Aurora's Avatar
^ Wow, there's something going on there for sure!
Old Jan 24, 2009 | 06:42 PM
  #84
LEDmod's Avatar
Try turning your dimmer switch
Old Jan 24, 2009 | 06:57 PM
  #85
ScionJim23's Avatar
yup, thats most likely it, turn that dimmer switch to the right....common mistake.
Old Jan 24, 2009 | 08:03 PM
  #86
lmao yeah I figured that out last night.
Old Jan 25, 2009 | 01:18 AM
  #87
Hey, if I use a 470ohm instead of a 330ohm will it be brighter? Will anything bad happen? like a fire or anything?
Old Jan 25, 2009 | 02:02 AM
  #88
LEDmod's Avatar
If you use higher ohm, it will get dimmer....
Basically higher the resistence (higher OHM number) less current flows so less power for the LED...
Old Jan 25, 2009 | 02:20 AM
  #89
oh so lesser ohm then?
Old Jan 25, 2009 | 03:41 AM
  #90
LEDmod's Avatar
Lower ohm, brighter it gets, but if you go to low, you'll over power the LED and LED will burn (it won't cause fire, but you can't use the LED anymore)
Old Jan 25, 2009 | 05:03 AM
  #91
cool thanks man.
Old Jan 26, 2009 | 12:22 AM
  #92
xbbox's Avatar
Revolt Imports
DeepSouth Scions
anyone know why the speedo needle would not move?
I've checked to make sure it isn't hitting anything or pushed down to far already.
Old Feb 4, 2009 | 07:35 AM
  #93
Is it ok to just change the 2 LEDs on the fuel, 2 on the temp, 5 on the speedo, 2 on the lcd, and the 3 on the rpm? I kinda want to just leave the other ones stock.
Old Feb 4, 2009 | 06:44 PM
  #94
LEDmod's Avatar
Make sure harness is plugged in properly.
Only one or all of them doesn't move??
This is for tC or xB??
Old Feb 4, 2009 | 06:48 PM
  #95
LEDmod's Avatar
Yea that is fine.you don't have to change every LED.
Old Feb 4, 2009 | 06:51 PM
  #96
KC7SCION's Avatar
anybody in Scottsdale / phoenix area willing to help me do this? pm me. will pay
Old Feb 4, 2009 | 07:06 PM
  #97
Awesome thanks man.
Old Feb 4, 2009 | 08:38 PM
  #98
mengsta's Avatar
hey ledmod is there a write up on HVAC leds? I think i wanna try that first before i attempt the gauges, seems easier that way..
Old Feb 4, 2009 | 08:54 PM
  #99
LEDmod's Avatar
Scion tC : HVAC / Climate Control LED Conversion Guide
https://www.scionlife.com/forums/vie....php?p=2676511
Old Feb 11, 2009 | 07:27 PM
  #100
LEDmod's Avatar
I hope this is helping everyone... any questions let me know..
Any improvements or correction will be appreciated...
Thanks..
