* tC : HVAC / Climate Control LED Conversion Guide
Old May 27, 2011 | 08:24 PM
  #101
fhalualani's Avatar
I'm wanting to swap out my LEDs with blue and white but i wanted to know if there are any specific blue and white LEDs I should buy. And if I'm doing that i was curious as to where to get the resistors and voltage regulator.
Thanks
Old May 29, 2011 | 05:25 AM
  #102
LEDmod's Avatar
Thanks
You can order it from here.
http://store.ledmod.com/index.php?ma...products_id=15
http://store.ledmod.com/index.php?ma...products_id=12
Old Jun 21, 2011 | 11:28 PM
  #103
LEDmod's Avatar
New lowered price with free shipping!!
Old Aug 7, 2011 | 08:25 PM
  #104
cyberbone's Avatar
So whats the new lower price? (it would be for a 05-06 tC)
_____
Old Aug 8, 2011 | 12:16 AM
  #105
LEDmod's Avatar
Price varies depends on different options. But staring price has been lowered and options ate lowered also.
Old Nov 27, 2011 | 09:00 PM
  #106
sommerz's Avatar
I've done 2 HVAC led swaps and am working on my third. This one seems to have more dim defrost, a/c and circulation button lights.
Any advice on what resistor or resistors or anything else that could cause this?
Please and thank you
Old Nov 28, 2011 | 06:24 PM
  #107
LEDmod's Avatar
Did you swap out the resistor already??
Old Nov 29, 2011 | 04:09 AM
  #108
sommerz's Avatar
Yes I did. It's the button lights, not the lights under the butttons, but to the sides. I've noticed they dim last after everything else on the hvac, if you use the dimmer on the gauge panel.
Old Dec 6, 2011 | 04:40 PM
  #109
LEDmod's Avatar
Check your soldering and also see if you didn't fried the LED (swap out with another new LED)
Old Oct 3, 2012 | 06:54 AM
  #110
rjl227's Avatar
Is there anyone in the Raleigh/Durham area that can do this for me? I just don't trust myself with the soldering. I could take everything apart, no problem.
Old Apr 1, 2014 | 04:11 AM
  #111
Dullivan's Avatar
I was able to do this swap a couple weeks ago along with the gauge cluster which i wouldnt have been able to do without these guides, they are great! However, during the drive back to school, the LCD screen on the HVAC flickers between fully bright, roughly half, and then cut to not having any back light what so ever and now does this every once in awhile since. The screen and everything works and is not broken so could this be caused by the resistor to the LCD having a bad connection? or one of the three LEDs? Everything else works except the back light.
Old May 5, 2014 | 01:07 AM
  #112
willie0503's Avatar
My best guess would be that the solder on one or two of the 3 LEDs isn't allowing for a good current.
I actually have the same issue on one of my lights for my speedometer.
Just haven't had the time to take it back apart to either resolder/replace the LED that's doing it.
_____
Old Nov 11, 2014 | 07:44 AM
  #113
5cion's Avatar
In regards to the install images....are they all duplicates images or are they for different HVAC units?
I just see the years...sorry for the dumb question.
Needing a install sheet for a 2010 Scion tC HVAC switch and all the images are confusing.
____
Old Nov 11, 2014 | 11:54 PM
  #114
electrongeek's Avatar
Originally Posted by 5cion
In regards to the install images....are they all duplicates images or are they for different hvac units? I just see the years...sorry for the dumb question. needing a install sheet for a 2010 scion TC hvac switch and all the images are confusing
Looks like there are a few duplicate images, but just pay attention to the model years. I did this mod twice and it wasn't that bad at all.
Old Nov 12, 2014 | 12:07 AM
  #115
5cion's Avatar
Thanks for the info..... I've done chevy silverado led conversions. Someone just asked me about a 2010 scion HVAC switch..... just needed to know the resistor/LED locations.
Old Nov 17, 2014 | 11:23 PM
  #116
Donlavon1's Avatar
Does anyone know of an easy way to remove the voltage regulator off? I tried to put the soldering on the wide side but it's not coming off.
Old Nov 20, 2014 | 09:48 PM
  #117
Donlavon1's Avatar
Hello. Do you sell the resistors separately? I brought your Led Ac kit but I lost two of the resistors trying to solder them (resistor 561 and 681). Thanks
Old Dec 31, 2014 | 03:58 AM
  #118
O5_TRD_tC's Avatar
Check out MengMotorsports.com, they provide LED parts and LED swap services!
Meng Motorsports LED Swap Scion tC 05-10 - Meng Motorsports
____
Old Feb 5, 2020 | 01:45 AM
  #119
Vinniet8's Avatar
Hey guys just wanted to share some extra info on this LED Conversion guide. I made a Youtube video on this a while back, just thought I would share this to help out!
Check out the video -
Other Helpful Scion TC Videos can be found here -
Youtube.com/VinnieT8
Hope this helps!
LEDmod
Scion tC 1G ICE & Interior
265
Nov 17, 2023 04:54 PM
LEDmod
39
Feb 12, 2013 02:22 AM
O5_TRD_tC
Regional - Pacific Mid
123
Jun 11, 2009 04:15 AM
Alex_C
19
Apr 13, 2009 02:51 PM
O5_TRD_tC
20
May 9, 2008 06:17 PM
