07 HVAC LED help
Old Jul 11, 2007 | 06:05 PM
rivas_203's Avatar
Default 07 HVAC LED help
how do you guys remove the voltage regulator thingy? ive been at it with solder braid trying to get all the solder off but it just wont budge. any tips on how to remove it?
Old Jul 11, 2007 | 08:21 PM
ScionJim23's Avatar
heat up the larger flat side first and then flip it up fast. Thats what i did. I Then desoldered the 2 small legs on it. Be carefull not to burn your board out.
Old Jul 11, 2007 | 09:14 PM
rivas_203's Avatar
ok yeah basicly i messed up bad. this is what ive got left of the old voltage regulator. its in all the faint circles.
since i think the only thing left is just metal, could i solder on the new regulator on top of that?
Old Jul 11, 2007 | 09:32 PM
SquallLHeart's Avatar
talking to him now.
Old Jul 11, 2007 | 11:11 PM
engifineer's Avatar
You need to remove it completely. Set your iron on a hotter setting if it has one and heat it till it will come loose. I raise the temp on my iron about 50 degrees while desoldering with a braid or desoldering heat sinks like that one. Remember, it is a heat sink, so it will take longer to heat the area and melt the solder.
hondajt
Dec 14, 2015 12:54 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
Subaru86
Sep 14, 2015 12:43 PM
SJMiller
Sep 12, 2015 06:33 PM
