2005 tc steering wheel removal???
Old Nov 28, 2006 | 10:01 PM
mr929dblR's Avatar
Default 2005 tc steering wheel removal???
I have searched and have found some answers, but mostly i found for a 2006, i am just curios if there is a difference.
This was thbest i have found, short and simple.
https://www.scionlife.com/forums/vie...+wheel+removal
my question is do i have to dissconnect the airbag, or could i just dissconnect the battery like stated in the above link for a 2006.
If the process is diferent and you know how to do it, please let me know.
also i might add my steering wheel does not have the 2 plastic pieces, but instead just 1 cover piece, covering the airbag.
thanks david
Old Nov 28, 2006 | 11:25 PM
SquallLHeart's Avatar
disconnect battery... wait few mintues..
two T30 torx screws on each side... pull... disconnect airbag. disconnect other wiring..
it's the same.. you just have two less things to remove.
Old Nov 28, 2006 | 11:28 PM
ziobep's Avatar
be careful if the air bag goes off your fcuked
Old Nov 28, 2006 | 11:31 PM
that's why you wait a few minutes AFTER you disconnect the battery.
Old Nov 29, 2006 | 05:07 PM
mr929dblR's Avatar
ok so once i have dissconnected the battery and waited, the airbag will be disarmed, and will not go off?
is there any precautions when putting the wheel back together?
thanks david
Old Nov 29, 2006 | 06:55 PM
uhm.. not that i know of... make sure wires are nicely tucked and won't get pinched when the airbag assembly is put back in... pretty much.
the airbag should be much safer to handle after a long wait after disconnection.. but precautions should still be made regardless.
you can never be too careful.
Old Nov 29, 2006 | 07:14 PM
mr929dblR's Avatar
thanks squall, ill let you know how it goes, if i get a black eye and a broken nose im coming after you!
j/k but seriously thanks, and your absoluetly right, you can never be too careful.
-thanks david
Old Nov 29, 2006 | 07:19 PM
well.. i've opened up the steering wheel before to do the radio control swap without disconnecting the battery.... but for that i only have to move the airbag and not remove/disconnect it completely...
if i need to disconnect it... yeah.. battery and wait a few mintues first.
Old Dec 6, 2006 | 08:13 PM
mr929dblR's Avatar
OK finally got around to it, i have been busy but everything went good, thanks for your help Squall.
Old Dec 7, 2006 | 07:24 AM
that's awesome. you're welcome
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
