Accelerator pedal?
Depends on the aftermarket pedal. AFAIK, it does NOT come off... at least is not intended to. When I put my OBX pedals on the new one slipped over the accelerator - where as the brake and clutch were removed and the new ones slipped over what was left.
I'm putting the MOMO pedals on. The clutch/brake slip off and the MOMO pedals bolt right on (sort of
)... but I can't find anywhere that the accelerator pedal comes off. Oh well, time for drillin'.
if u get the obx ones they just slip over the pedal after the stock rubber pieces are takin off. although it takes quite an effort. if u get any other aftermarket ones they usually have clamps or double sided tape holding them on. although i found it better to just drill them and screw them on my older cars.
Originally Posted by hawgs74
Your probably goona have to mount it off center a little bit because there is a big bar thing on the back of the accelerator pedal.
Did you have a problem with the glue on yours? Because the glue on mine is straight up terrible. You'd think with enough Italian stallions running around, they could make some decent glue.
Blunderbuss
Oct 8, 2015 04:56 PM
