blew tweeter again in component speakers.
For about a year. I haven't touched anything other than rewire my speakers behind the headunit, and I read the manual for that. I'm going to pop open the door panel or if I can't I can just take it in under warranty and see what he says.
Haha really? That's crazy... it is possible, just sounds crazy though. What about my hpf? Is 70hz good or should i turn it up a little more? I like a little bit of bass but I don't want to blow my speakers. Do you know anything about the Memphis Audio component speakers? Those are the speakers I have installed, I'm just guessing the speakers are more for clarity than mid-bass.
i don't think its any of that. whats your crossover point. just because you're using passive crossovers doesn't mean your hpf isn't set way low and depending on the shop they'll not do it. you need to set your hpf way higher than 50 or 60 more like 5k - 7k
It sounds like you don't know what your doing. Take it to a Memphis authorized dealer before you do any more damage. You also voided the warranty by installing them yourself. A word of advice- do your homework before you mess with expensive equipment. FYI, set the HP at 80hz as well as LP your sub at 80hz also. Preferable both at 24db slope. Gain is very important in setting up amps. Good components should handle down to 50hz with no problem. Be sure to deaden your doors also.
no it doesn't matter you can feed your amp different imputs from your headunit or eq. and yes you can still blow your tweet with a passive xover.
if you want to boost the frequencies above or below a xover point to "change" it you risk clipping the signal. not to mention the manufacturer set the xover points there for a reason. this would be a very bad idea for somebody that has limited car audio knowledge, only has a 3-band eq and is already having trouble with their system.
the passive filters it but does not set it. if you have the right eq in your headunit you can set it higher than the passive point
No.
To clarify: You can't change the xover point in a passive network (without re-designing the filter). The frequency of the filter is a relationship with the speaker, based on impedance.
Normally (in car audio) the installer creates a "bandpass" filter by high-passing the output of the amplifier that feeds the passive network. Of course the network has a built in low pass for the midbass...making the frequency range of the midbass something like 80-1.5KHz. The highpass network for the tweeter is part of the passive, and no additional/external filtering or protection is required. Most passive networks have tweeter protection built in (DC offset, over voltage, etc.) RARELY do these perform inadequately - and allow the tweeter to blow.
www.bcae1.com - section 54
didn't you sell your car yet?
and yes you can. the passive well let it not go below a certain point but that does not mean you can't change the hpf on the amp or on the HU to redirect the signal going into the passive crossover. Typically the passive xover will have them set lower which is why i turn the xover point up a bit.
