converting back to stock problem..
Originally Posted by Nick06tC
Go to radio shack and buy the pin connectors that fit those plugs. Pull those wires out (write down the coloring first).
Put the pins on the wires in the car and plug them into those plugs.
They will be really tinny pins that attach to the wire then clip into the white harness inside.
get a set of eye glass tools. You know the REAL tiny screw driver?
use it to release the pin, but dont crack the plastic. if you just pull the wire, it will pull the wire out.
You might even be able to reuse the pins, not to sure tho. Soldering is going to be tedious, but wil deffinetly work.
rcflyer15
Dec 5, 2014 05:15 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
umnitza
Dec 1, 2014 06:26 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
