DIY: LEDs in cupholders. Lots of pics. Very detailed.
Old Jun 24, 2009 | 09:16 PM
Mikeydizzle's Avatar
Radioshack for the LEDs, resistors, and butt connectors, Home Depot for the wire.
Old Jul 5, 2009 | 04:32 AM
BlkRS5's Avatar
This was a great write up. I just installed the same LEDs (red) In my RS 5.0. I hooked it up to the cubby hole light to draw power so there on when my lights are. I'll post pics soon. Thanks again for the write.
Old Jul 5, 2009 | 04:34 AM
BlkRS5's Avatar
Old Jan 24, 2014 | 06:18 PM
Gore's Avatar
Would it matter if the butt connectors are insulated or not?
Old Jan 27, 2014 | 09:17 PM
that_G_U_Ys_tC's Avatar
Nice write up, maybe i should look into to doing this along with changing that OEM amber color on the dash :-)
Old Jan 29, 2014 | 07:21 PM
TC1's Avatar
TC1
Great job. I will have to do something very similar soon. Love the look.
Old Mar 4, 2014 | 05:27 AM
Gore's Avatar
Okay so I'm really confused about this part, I finally got everything I need so someone please clarify this, I'm not sure where the LEDs positive or negatives would connect. I saw the picture but wasn't complete sure. how do I know what connection is negative and what is positive? Say the wires that meet between the LEDs are negative does that mean both the wires coming out are positive? But then how would I ground one wire an the other one connect to a 12v source? Any suggestions on this? Giving me a head ache. Or would one wire be negative and the other one positive even then it means the wires connecting between the LEDs are a positive and a negative and that doesn't sound correct
Attached Thumbnails DIY: LEDs in cupholders. Lots of pics. Very detailed.-image.jpg
Old Mar 4, 2014 | 01:31 PM
DaWiz711's Avatar
The positive lead on the led is typically the longer one. Each led usually consumes 3.2ish volts so you can safely run up to three in series, with a resistor to adjust the voltage accordingly. Google LED Array Wizard, the website is chock full of good info but the wizard itself is awesome, generates easy to read wiring diagrams and all. Disclaimer: your leds should have come with a data sheet which included the recommended voltage; some diy car mod companies prep leds for 12v applications in which case everything I said above wont apply.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old Mar 4, 2014 | 03:53 PM
Gore's Avatar
I know my LEDs are 12v ready with a resistor already integrated but I'm not sure how he set up the cup holder my previous post I attached an image in the part I'm confused with. I might just attach negative to negative then run to ground (bolt my ebrake) and positive to positive (cig lighter) and run the wires through the bottom of the cup holders instead of the sides like in this DIY
Old Jan 10, 2018 | 08:43 AM
MR_LUV's Avatar
Administrator
Administrator
Thumbs up
Nice DIY! This becomes a Sticky!
VitaminE
Mar 24, 2015 03:36 PM
CPL_Radar
Mar 5, 2015 05:42 AM
TheTripleC
Jan 4, 2015 06:46 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
Besk_one
70
Dec 31, 2003 05:21 PM
