DIY: Switchblade Key Conversion
Old May 21, 2009 | 05:31 AM
x_Batman_x's Avatar
watchin
Old May 27, 2009 | 01:41 AM
ack154's Avatar
No new news or anything... still waiting on the key. I'm hoping to have it towards the end of this week or very early next week.
Old May 27, 2009 | 05:36 AM
jaywo_23's Avatar
Default I did it!
My key came in and i got it to work. I cut the chip out and put it in the new one.
Old May 27, 2009 | 06:14 AM
GrnBrownies's Avatar
watching!
Old May 27, 2009 | 03:49 PM
o8tC's Avatar
awesome idea...def watching.
Old May 27, 2009 | 04:48 PM
jaywo_23's Avatar
It was really simple to do. The hardest part for me was to find someone to cut the key. Lowes and Home Depot wouldn't do it for me.
All you do is un-screw the back, pop the remote from your old key in and the transponder chip. I decided to cut it out with the dremel it out. It needs to be about the same size as the chip, other wise it won't fit. I was trying the hair dryer trick that someone mentioned before. That was taking forever. Pop everything in and when you are putting the spring back in you need to twist the cover back on so that it will pop out.
Good Luck. Let me know if you have any problems!
Old May 27, 2009 | 06:30 PM
ack154's Avatar
Thanks for the advice! I'm getting pretty anxious for the key to arrive.
I've heard different things on who will or won't cut it... so it seems like it'll just be trial and error.
Old May 27, 2009 | 06:51 PM
jaywo_23's Avatar
well the key cut was brutal. It looks like it was super worn down but it works. Took 2 tries but the guy did it for me for free.
Old May 28, 2009 | 01:09 AM
ack154's Avatar
Ouch! Hopefully I have some better luck with that. I might try a hardware store I had do a house key not long ago. Do have a Lowe's and Home Depot nearby... but sounds hit and miss.
I was thinking I might try to get the transponder out tonight. I have an actual heat gun... and might be able to get it out that way. Will keep this updated.
Old May 28, 2009 | 01:29 AM
ack154's Avatar
OK... transponder is out. Hopefully it survived the near oven I subjected it to.
EDIT: Transponder is A-OK. Reassembled dissected key minus transponder and took it to my car. Inserted key and immobilizer light continued to blink as expected. Held chip up next to the key and the light went out.
So far so good.
Old May 28, 2009 | 03:01 AM
Default Re: My Key Conversion Project... Updated 5/27
Originally Posted by ack154
Yuck. I'm not sure if those grey/black keys are only made for the 05-07 models but they look horrible after a couple years. The one I have for my 08 is too bulky in the area with all the buttons. I might have to give this a try sometime in the future!
Old May 28, 2009 | 03:03 AM
ack154's Avatar
Ya, that one in particular is pretty gross. My other one is basically brand new and looks OK still.
My g/f's new xD keys are the black ones and much nicer.
Old May 28, 2009 | 05:51 PM
ack154's Avatar
So I got a notice today about a registered mail package. Will have to see if I can pick it up today instead of tomorrow morning like it says.
Old May 28, 2009 | 07:46 PM
dwaine's Avatar
Were you able to pick it up?
Old May 28, 2009 | 08:51 PM
ack154's Avatar
Check first post...
Old May 28, 2009 | 09:36 PM
ack154's Avatar
Key is cut (free at Home Depot!). Now I just have to program.
I tried to program in the Home Depot lot but it wasn't responding ( :teeth: ). I'm going to try to remove all of them and try again. I think there might actually be a limit.. I just don't know what that is.
Old May 28, 2009 | 09:53 PM
ack154's Avatar
Having issues with programming. Grr...
Old May 28, 2009 | 10:00 PM
jaywo_23's Avatar
are you doing the programming that came with it? I just took out the button part and put it in the new key. That way its already programed.
Old May 28, 2009 | 10:23 PM
ack154's Avatar
Sometimes it's the little things that I forget.
The good news is the key works great! The bad news is I had to peel the plate off so now I don't have a spare if I ever end up having to replace the battery (but I did put in a brand new lithium battery from Radio Shack just now).
Old May 28, 2009 | 10:26 PM
jaywo_23's Avatar
peel the plate off?
