Double Din Mounting Kit
Old Sep 21, 2008 | 06:38 PM
goin2c3's Avatar
Default Double Din Mounting Kit
http://www.crutchfield.com/S-2Ehk0rh...x?I=130P8000BT
What do I need to fit this in the tC?
Old Sep 21, 2008 | 07:16 PM
mattieg's Avatar
Well you really dont need anything. Although if you want the door to close you will need to redrill the screw mounts. Basically where you see the dimples on the metal brackets you will need to drill. Also there is a plastic bracket that they make that you will need to fill in the gaps on the left and right hand side of the aftermarket radio. The stock one is a little wider. Let me find it for you...
Old Sep 21, 2008 | 07:24 PM
mattieg's Avatar
http://www.crutchfield.com/S-0sKfAj5...px?i=120958202
Old Sep 22, 2008 | 02:48 AM
redhot_1_0's Avatar
awsome!! i've been looking for this for a while now!!
Old Sep 22, 2008 | 06:55 PM
mattieg's Avatar
Well good luck guys and have fun with it. If you have a stock sub make sure you hook up a remote turn on wire from the aftermarket radio, to the blue power antenna wire. It will be the blue wire in the harness you bought that plugs into the car side. Scosche part number is 70-1761
MinusPrevious
15
Jun 13, 2015 11:40 AM
debris
Mar 13, 2015 08:15 AM
Scion0814
Scion tC 1G Aero & Exterior
Feb 15, 2015 10:02 PM
Basebllstar
Dec 17, 2014 07:30 PM
lunchbx05
Dec 11, 2014 06:13 PM
