The Dreaded ERROR-4 message.
Old Mar 18, 2010 | 06:14 PM
JoeyC20's Avatar
Default The Dreaded ERROR-4 message.
Yes, its an 05. Yes ive searched the forum and i know my headunit probably needs to be replaced. However, I have the ERROR-4 message which ive gotten it in the past only this time turning the car off and back on again does not resolve the problem. Ive tried resetting the ECU by unplugging the negative on my battery. I still get the blinking error 4 message and i can only play the radio.
Is there anything i can do to get it to work again until i get to replacing the headunit? Or am i basically screwed?
Thanks for any info.
Joe
Old Mar 18, 2010 | 09:14 PM
Jiggaman's Avatar
Big Sky Scion
super common problem for the older models
the remedies that i have seen have been brought to the dealers, and replaced from there, but you are probably out of the loop for warranty work
Old Mar 18, 2010 | 09:25 PM
JoeyC20's Avatar
Thanks for the response but unfortunately no warranty.
Old Mar 18, 2010 | 11:55 PM
Kanchi's Avatar
at least the used stock decks go for a reasonable price on here, good luck dude! That sucks!
Old Mar 19, 2010 | 08:59 PM
sciontc_mich's Avatar
or just go with a nice aftermarket unit
Old Mar 19, 2010 | 10:09 PM
tCjosh's Avatar
hey i have an 06 stock hu if you want it for 20 bucks... let me know!
Old Mar 20, 2010 | 03:53 AM
JoeyC20's Avatar
Is it in working condition and doesnt have any error messages? BTW since my car doesnt play cds now. Is there any way i can at least get them out?
Old Sep 26, 2010 | 11:32 PM
rideevol's Avatar
To repair the error 4 you need to re-lube the internal metal mechanisms of the changer. Apparently the original white lube wears out or dries up.
It took me four attempts to disassemble deeply enough and find the correct lube.
If you are very technical, you need to unlayer many circuit boards to reach the multiple sliding surfaces.
Its been awhile, but I think I needed to desolder some ground attachments.
The lube that works long-term is a combination of marvel Mystery oil and white lithuim grease.
My headunit's repair is still working perfectly.
mgaines
Jun 14, 2015 11:39 PM
Maarifa
Mar 13, 2015 04:07 AM
mischman
Jan 14, 2015 06:07 PM
aparrado
Scion tC 1G Aero & Exterior
Jan 14, 2007 10:31 PM
satanisanerd734
14
Jul 9, 2006 02:37 PM
