Engine Noise (isolators?)
i dont think so... the amp is supposed to come on when it gets voltage from the remote turn on wire (which is supposed to be spliced into a wire that turns on when the ignition comes on). That's completely normal.
good luck fixing it tommorow
I brought it to circuit city today and they disconnected my stock HU and the line-out converter. They put in a different HU and it sounded all better. I have to get one of those bad mothers now. What do you all think about this HU:
http://www.eclipse-web.com/cd/cd3000.html
The remote wire is connected to the ignition because it can't be hooked up properly to the stock HU - another reason to get an aftermarket HU.
The speaker wire and RCAs and power wires are all run properly along the car. Seperated on each side an all. I have the 1 ground loop isolator on the front, and I could add another to the rear if I must.
The grounds are good, connected to the seat belts, circuit city says that its good.
The speaker wire that i'm using is not too good - not shielded. I like the idea of foil tape to wrap around the speaker wires and rcas though.
What do you all think of that HU?
The line converter is a possibility...i have the walmart scoshce line-out convertor, it works ok for me....
plus wires, possibility but with a DIS its not as likely(distributor-less Ignition System, a new acronym i learned today
check your line out convertor, and put a switch in the remote if you need to on the amp for testing....there is something we're missing, no one else has this problem...
Edit: speaker wire could be part of the problem if it is unshielded, as it picks up interference easily...
I think that going with the new HU will solve multiple problems. First, I won't have to deal with fixing that remote wire, the new HU will be much more straight forward. Also, this way I have no line out converter. The sound quality will be better. And since its an eclipse, I can still keep my steering wheel controls. However, I may still want to put in new speaker wire as so many of you are telling me.
I thought I was doing well when i bought speaker wire, but cc told me otherwise. This is what I bought and have in, is it crap?:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
Any better alternatives that don't cost $1 per foot?
Anyway, I swapped out the amp for a Pioneer GM-6100F. I got it from circuit city for $80....now THATS a steal. They had it on clearance and I haggled them down. The RCAs are fine, at cc I had them open up the best RCAs they had and we temporarily ran it and made no difference. Mine are shielded anyway. I then put in the SVEN4 line out converter. Still a little noise, so the only thing left is the HU!
What do you all think of that amp?:
Pioneer GM-6100F
Pioneer GM-6100F
