Fixed; MODS: DELETE/LOCK PLEASE
I'm at a standstill yet again. I plugged in my right door panel to test the clearance of my speaker with the window down, and the window doesn't work. The lock button does though. I test the driver panel, and sure enough, the drivers window goes down, the lock button works, but the button to control the passenger window doesn't do anything. It lights up, but it doesn't work. The other button doesn't even light up.
The only two things I can think of, is that I pulled a wire loose from the harnesses behind the kick panel, or the tweeter wiring caused something when I fired up the amp to test my woofer.
I don't feel like buying an overpriced wiring harness for my right door from the dealer. Any ideas? I checked all the small fuses in the box in the engine bay, nothing is burnt out.
P.S. This is not a matter of resetting my windows.
No, a wire was actually stuck in the compartment between the boot and the inside of the car. Fun times getting that sucker out.
I really need to be more observant before I post threads. I seem to have a bad habit.
