Getting better sound out of AUX port?
Old Feb 27, 2008 | 08:52 PM
decline1822's Avatar
Default Getting better sound out of AUX port?
Is there a way to improve the sound from the AUX port on the tC's stock head unit?
I've noticed that CD's sound MUCH better than my Sandisk MP3 player, laptop, or iPod when plugged into the AUX port. Also, it seems the SRT function is only available for CD audio and not AUX-in.
Any advice?
Old Feb 27, 2008 | 11:39 PM
DanielNC06's Avatar
mine sounds great...a common mistake is turning the device all the way up...that can be maxing out its amp, and it'll give you lil cracks adn pops.....also, running the EQ on the device and the car radio can cause bad quality..choose one or the other......and the last thing thats sometimes a gimmick is a good patch cable..
Old Feb 28, 2008 | 02:09 AM
aRucard's Avatar
get one of these:
http://www.discountcarstereo.com/detail.aspx?ID=1035
Old Feb 28, 2008 | 02:57 AM
paul34's Avatar
Old Feb 28, 2008 | 11:33 AM
is there anything you can do in windows to push the volume output passed the 100% level?
I mostly use my Samsung Q1 Ultra Mobile PC and it only has a headphone port.
Thanks for the replies.
Old Feb 28, 2008 | 11:37 AM
skiboarder72's Avatar
my zune sounds great hooked up with an 1/8" stereo jack into the aux port in the car, i crank the volume no problem...
Old Feb 29, 2008 | 12:51 AM
What do you have for an audio system?
--12" Kicker Solo Baric ~ 800w Rockford Fosgate Amp
That's why.
I just have a stock system with the 10" bazooka sub woofer option. CD's sound MUCH better than my AUX port. I'm not saying the AUX port sounds bad, the MP3 CD's are just way better.
Old Feb 29, 2008 | 01:08 AM
crush02342002's Avatar
I found a thread on here about pressing your ssp button for a few sec and switching it from tc to xa. I did this and switched it to xb(it has more bass and a little louder) I found my mobile phone/mp3 player sounded better and louder. All you do is press the ssp button for a few seconds and toggle through the different models till you find one you like and sit back and enjoy.Try this for a quick and easy fix. By the way i have the same set up (stock radio and 10" bazooka
Old Feb 29, 2008 | 03:12 AM
Does anyone know of a site that explains what the Xa, Xb, and tC settings actually change?
Old Feb 29, 2008 | 10:29 AM
I dont really know of one but i can tell you xa is the loudest and has more treble, xb is sort of in the middle (loudness) but has the most bass, Tc well this setting (imo)kinda sucks its not very laud and makes the music sound funky. Have you also tried to mess with the settings on your bazooka, all you have to do is pop the grill off to reveal all the switches, play with those to get the sound you want. None of these are miracle fixes for week aux sound but they can help. good luck
Old Feb 29, 2008 | 12:48 PM
tCeeder's Avatar
i use the audio jack from my ipod and plug it in the aux port in the armrest.
as for head unit settings, i put the bass and treble to 5, output to front-2, and SSP to feel. on the ipod, the volume is maxed and the treble booster equilizer is on. i control the volume via the head unit ****, at '30' during the day is when i would consider it to be medium loud. all my mp3's are at 192 quality. sounds really good, no problems!
however IF i plug in the bottom dock adapter that goes into my cig lighter to charge the ipod while its playing, you can hear noise in the background of the music so i avoid that. it actually gets more high pitched when your RPMs go up, so i try to charge it when i decide to listen to the FM radio instead.
and now, if i pop in a store-bought CD, the quality is a tad better but not really noticeable.
Old Feb 29, 2008 | 12:55 PM
Will this work on a stock scion stereo?
http://www.discountcarstereo.com/detail.aspx?ID=762
Old Feb 29, 2008 | 01:50 PM
I have that same problem if I plug in the charger to my MP3 player. It sucks.
Old Feb 29, 2008 | 02:08 PM
I think I found what I need thanks to the support at the site aRucard recommended
http://www.discountcarstereo.com/detail.aspx?ID=317
It's a line driver that basically amplifies whatever sound goes through it. I am considering picking this up.
Old Feb 29, 2008 | 02:28 PM
Actually, I might get this instead since I can pick it up in town and it uses the right size audio jack:
http://www.radioshack.com/product/in...rt&tab=summary
Old Mar 3, 2008 | 09:26 PM
bam099's Avatar
This is solved with a ground loop isolator. Common problems in all the stereos that I have ever installed. I have read that if you try to seperate the audio cables from the power cables it helps but now I just buy one of these bad boys. 17$ well spent and it will solve the problem of that alternator whine noise. Hope this helps.
http://www.radioshack.com/product/in...entPage=search
wiltonhall
Jun 23, 2025 10:09 PM
Cromzinc
Scion tC 1G ICE & Interior
Jun 28, 2015 01:28 AM
charlie4
Jun 12, 2015 01:51 AM
corbmonster
Jan 24, 2015 05:22 PM
RichBinAZ
Dec 21, 2014 12:05 PM
