Ground Loop Isolator Question
Old Nov 13, 2008 | 01:56 PM
MaxxFMTC's Avatar
Default Ground Loop Isolator Question
I am trying to run both my Sirius and my iPod through the center console inputs. I am powering up both through the console's power supply (using a Y-splitter). I also have both hooked up to the AUX port through a Y-splitter. I was getting some serious interference, so I hooked up a Ground Loop Isolator- first immediately off of the AUX port, then wired on the Sirius side of the splitter (which has the most noticeable amount of interference). Neither scenario works very well. In a case like this, would it be beneficial to hook up 2 Ground Loop Isolators- one for each device? Or is there another solution?
Old Nov 14, 2008 | 01:44 AM
Rawkerstatus's Avatar
try to get a ground away from any other wires. that usually works
Old Nov 15, 2008 | 03:41 PM
MaxxFMTC's Avatar
I really don't want to have to mess with any rewiring....I would like to fix this problem as simply as possible. If its the only way though, how would I go about wiring in a new ground?
Old Nov 15, 2008 | 03:49 PM
HomelessGuy's Avatar
what kind of interferience are you getting? if your getting static and such, or no signal through your sirius, its probly a case of the power wire being too close to the antenna wire, or the AUX cable. do you get the same interferience if you just plug in one device? I would immagine if you had a ground loop, using one isolator would be sufficent. but if your realy unsure, just go to radio shack and pick up another one, if it doesnt solve your problem, return it.
Old Nov 16, 2008 | 08:30 PM
mattieg's Avatar
i ran into similar problems with other cars. They share different grounds between the radio and the aux change. What you need to do is move the ground from the AUX jack to the ground on the radio.
Old Nov 17, 2008 | 03:22 PM
MaxxFMTC's Avatar
Yeah I started running into this problem once I started using this: http://www.griffintechnology.com/products/autopilot
which basically charges and plays my Ipod at the same time, and untilizes the ipod jack instead of the headphones output. The sound is much better, but now I am running into alternator whine again real bad. I am guessing HomelessGuy is right- that the AUX imports are just too close to the power plugs for both units.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
