I need help with these Gauges
Hi guys, I checked out the DIY from Kaeon and it looks complicated. I bought the AFR and oil pressure from glowshift and im scared to do this stuff. Does anyone have an easier install for these things because i dont want to install these gauges by making a hole in the s pipe lol. thats too scary. but if there is someone here in miami that could help me out or if someone could explain how to install this better please help me. Im not bashing on Kaeons work, he did an awesome job but its complicating for me.
Thanks
Thanks
For the AFR gauge you can have someone put a bung in for you and then go home and finish up the job. That's what I did, My Autometer o2 sensor came with a bung and a plug. I had my mechanic drill out the hole and wield the bung in place. OR I know that some people were using what they called "vampire" taps. Basically the "vampire" tap would be clipped onto the wire to the ECU for the already inplace o2 sensors. Check around, I know a few guys on this site have been able to tap off that wire. I don't know about the oil gauge though, sorry. Hopefully it's a little more help.
I just took a few pics right now of everything. Ghost that helps a bit but i need to search for the vampire things you are talking about. What gauge wire do I need to extend these? Also is there anyway that I could atleast let them light up for now?
these are the gauges
for the afr gauge
more afr
The afr wires
OIL pressure instructions
Oil pressure again
Oil sender
Oil wires
for the afr gauge
more afr
The afr wires
Oil pressure again
Oil sender
Oil wires
As far as getting them to light up all you have to do is hook the power sources up. . . ie ground and power. As far as extending them I used 18 gauge wire, however the autometer AFR gauge came with some really long wires. I'm no expert but I figure the same gauge wire is the way to go. . . I belive it's about 16 gauge, but I am not sure. I have a huge roll of 18 gauge laying around so I just used what I had. Do a search for "vampire" you might be able to come up with something. I'll tell you this much, if it gets to complicated or you are in doubt you might want to have a shop do the work. My mechanic is also my fellow co worker, I have a luxury that most people don't have. I will tell you though if I had to wire these things bymyself, I probably would have found someone who knew what they were doing. . . I don't know how much more help I can be.
the "vampire" clips are more commonly known as 3M scotchloks and they are available at any radio shack or home depot. they may also go by 3M wire taps.
and they look like this:
http://multimedia.mmm.com/mws/mediaw...666WxJc7rrrrQ-
ok cool, so on the oil pressure to make it light up, it says the red wire on it has to go on a 12v ignition switch and the orange to headlamp other 12v source. Where do you suggest i place these?
nice someone who knows about those "vampire" things. . . BTW here's the post for the xB I don't know if it will help but hopefully it'll give you some ideas.
https://www.scionlife.com/forums/vie...957&highlight=
so basically i get the wire for the afr (o2 sensor wire) and connect it to the o2 sensor wire coming off the s-pipe??? lol i think i might try and find a shop to do it, i hope they wont ccharge much.
also the red and orange wire on my oil pressure, can i just twist them together and connect it to the battery?
Not sure about this so hopefully someone else will chime in. . . as far as my temp gauge goes. . .
Power is tapped into the cigarette lighter wiring. This is done because from what I can tell the oil pressure sender seems to have almost the same set up as my temp gauge. so the top part of the diagram is for the light bulb.
I just took a look at my diagram for my temp. gauge, it's only got two wires but your set up has one more wire. To be on the safe side I don't recommend twisting the wires together. . . mainly because the way I see it. your set up would have been more like mine where it's only a power wire and a ground wire. I'm going to assume one is to tell the light to stay on only when the car is on and the other is for actual power to the bulb. I hope I'm not confusing you. I believe they want you to use the headlamp wire so that the backlight only comes on when the headlamps are being used. I noticed you have glowshift gauges. If I rememeber correctly the black faced when the car is off and only light up when you turn the car on. . . that could explain the two power wires.
FYI I used the cigarette lighter cause I never use it and I wouldn't like to be the one going through the wiring harness to find the ignition wire. . . also when I turn the car off the light goes out. Only down side is the light is on even when the headlights are off. I could be wrong though. Sorry if I am confusing you. Hope this helps a little.
no its not confusing at all. the only problem that i think is of overloading the cigarette lighter. because i have the cathodes hooked on to it and i have my radar connected to it. if i connect the afr and oil pressure to it will it be ok? so for the extra wire, all i need to do is buy longer wire and connect it to my headlights?
I'm not sure. . .if they mean the headlight switch or the headlight wiring. . . If I only knew why it needed to be connected to it. What about wiring it into the fuse box. Find a fuse like the clock or something and wedge the wire into it. I've got my fog lights and Temp. gauge plug into the the clock fuse and I forget the other at the moment. If you do end up doing that find a fuse that gets no power when the car is off. Otherwise you might have the gauges on all the time and kill the battery. For instance my fog light switch is in the clock fuse, sometimes I forget to turn off the lights at the switch but the clock goes off when I take the key out of the ignition so the fog lights go out also. It might not be the best way but not only does it work it also is pretty easy. . . well not wedging the wire into the fuse socket with the fuse. . .ha ha ha. Of course since I haven't said it before try at your own risk. I did it at my own risk . . .hehe.
lol, so i should find the clock wire and tap it into it? or just place it into its socket? lol its gonna be funny shoving it in their, i hope it will support its power. Th afr should be easy because its just a black and red wire, well it has a grey wire but thats for the o2. so i can just ground the black one and put the red one on the cigarette too.
Not the clock wire. . .
1. find a fuse that gets no power when the car is off, on the xB one of them is for the clock. The reason for this is you don't want the gauge to constantly on and/or draining unneccesary power from the battery. (easy to do if you have a test light)
2. Take the fuse out.
3. take the wire and put it into where the fuse goes
4. put fuse in. ( this might be a little fustrating and time consuming)
when you put the fuse in the wire is going to make it really hard to fit it in. I see aftermarket alarms wired this way all the time. . . as far as I'm concerned it's not the right way. It works though, I have had my foglights wired this way for about a year now.
lol im going to have to wait till monday for this stuff. because the guy thats helping me out needs to see the o2 sensor for the afr gauge. he said hes gonna tap the gauge wire to the o2 sensor in which it should work. but they said that there is 3 wires, a white one and 2 black ones. so we have to make a good guess lol. and the oil pressure, we will figure it out.
just do what nick06tc said, like I said before the way I did it isn't the correct way but it works.
about the 1 white wire and 2 black wires. . . I had forgotten about that. Things got so complicated and stupid the mechanic I work with said let me just drill a hole in your exhaust pipe. We had a good laugh. It's funny how simple this stuff is and yet it seems so complicated. I wonder if this thread is going to help anyone else. '
